Page 1 of 17 12345611 ... LastLast
Results 1 to 15 of 253
    user2468's Avatar
    Sep 2009
    Planet Earth
    Default XPROG Clone Repair
    Hello here is tutorial how to repair your xprog clone,
    in this way i repair my xprog, and Verify Error 100% OK Now!
    My XPROG was broken after i click update firmware button!
    Updated Tutorial Here
    If my post was helpful than Please don't forget to press the Magic word
  2. The Following 31 Users Say Thank You to user2468 For This Useful Post:
    Aliazadar (21st March, 2018), ampibali (8th October, 2013), arif16 (12th November, 2023), beongo (2nd July, 2013), canisha (9th January, 2022), cicko (8th August, 2013), den5 (15th April, 2013), djfreesound (27th July, 2018), dtxcrtt (18th February, 2023), ecufix (25th June, 2013), elangel0001 (12th April, 2013), elektronic (13th May, 2013), estwood68 (8th March, 2016), haingoben (14th January, 2015), hass42 (25th March, 2013), IchBins (29th March, 2013), jarro (9th August, 2013), kronk92 (13th October, 2016), madbg (26th March, 2013), Madol1 (23rd April, 2016), mahmoudelkholy (15th September, 2018), mandjeadolphe (27th August, 2014), rex89 (8th December, 2013), saibox (29th June, 2014), scarymistake (1st April, 2013), SEM (20th December, 2013), SergeyIg (20th September, 2014), tehnosoftex (31st March, 2013), usefi5961 (28th December, 2023), wieslov (25th February, 2014), ZYX (18th October, 2013)
  3. #2
    Mar 2010
    Default HELP
    Quote Originally Posted by user2468 View Post
    Download Tutorial Here
    AFTER FRIMWARE YOU LOST ALL AUTHORISATION?
  4. The Following 2 Users Say Thank You to 3abas27 For This Useful Post:
    dtxcrtt (18th February, 2023), usefi5961 (28th December, 2023)
  5. #3
    user2468's Avatar
    Sep 2009
    Planet Earth
    Yes i lost authorizations, but ned to update firmavare using version 5 how explain in readme.txt then everything will be ok
  6. The Following 3 Users Say Thank You to user2468 For This Useful Post:
    Aliazadar (21st March, 2018), butugan_mihai (15th April, 2013), dtxcrtt (18th February, 2023)
  7. #4
    Dunker's Avatar
    Yorkshire
    Worked like a charm. Just need something to try it on now.
    Thanks.
    [EDIT]
    Tried it on serial eeproms - ok as usual, also tried with 68HC908AZ60 3K85K and 9S12H256 1K78X and no verify errors (these are an old Ford dash and Renault EPB I'm sure these had the odd error before). Clone is the one with the plastic round edged case with dark blue-ish PCB. It was originally V4.5 when new.
    [/EDIT]
    V Series TMS470 / EEPROM data - encryption / decryption, totally pwned.
    IEC 62056-21 - new discussion: sonsivri.to/forum/index.php?topic=60412.0
  8. The Following User Says Thank You to Dunker For This Useful Post:
  9. #5
    jarripote's Avatar
    Apr 2010
    Thank you very much for your tutorial, tell me, your clone is the bringer dongle?, Thanks
  10. #6
    user2468's Avatar
    Sep 2009
    Planet Earth
    no my clone has no dongle, i think is the same!
  11. The Following 2 Users Say Thank You to user2468 For This Useful Post:
    carber78 (28th August, 2016), dtxcrtt (18th February, 2023)
  12. #7
    Mar 2010
    Default help
    after repair your clone xprog freind
    you can use it now with soft 5.3.5?
    what did win like news when you repair yours
  13. #8
    dantetimoc's Avatar
    Mar 2010
    heheee! Good solution! i have repaired my xprogm clone 4.5. Now is alive and working as v5!
    TNX1
    Autotuner- Kess 3, genuine master tools.
  14. The Following User Says Thank You to dantetimoc For This Useful Post:
  15. #9
    Mar 2010
    Default THANKS
    Quote Originally Posted by dantetimoc View Post
    TNX1
    SOLUTION TESTED TODAY ALL OK
    NO VERIFY ERROR
    1000 THANKS TO MAN WHO POST THIS SOLUTION
  16. The Following User Says Thank You to 3abas27 For This Useful Post:
  17. #10
    Sep 2009
    Bulgaria
    thank you user2468 work perfekt
  18. #11
    Feb 2010
    i have problem whith device is silent , i write all the files ok and configuration too, but when i try to update say to me device is silent usb port is ok too
  19. #12
    DK Veteran stevan's Avatar
    Dec 2008
    Bosnia
    update over Com port
  20. #13
    DK Veteran rachmach's Avatar
    Jan 2011
    Workshop
    hi
    i want toknow if i can repar my xprog after a short-circuit whene i try to read a fis module ??
  21. #14
    user2468's Avatar
    Sep 2009
    Planet Earth
    Why not! Of of course you can repair your xprog after short circuit, xprog is like all another electronic devices.
    Which pin has short circuited with fis module? Or open your xprog and have a look in wiring who is connected the pin who was short circuited, take a multimeter and make measurements.
  22. #15
    May 2011
    Hello mates, i have a little problem with my Xprog clone, when i try to read EWS3 via K-line, led green on Xprog only blinking and can't read ews3 via k-line. Anybody can help me.
    Best Regards.
