Page 7 of 17 FirstFirst ... 23456789101112 ... LastLast
Results 91 to 105 of 253
  1. #91
    Nov 2009
    Hollywood
    New software version is available for original X-ProgBOX users.
    V5.0.0
    Added new devices...
  2. #92
    serg2000's Avatar
    Apr 2011
    Ukraine
    Please upload version 5.4.9
  3. #93
    user2468's Avatar
    Sep 2009
    Planet Earth
    eldb XPROG
  4. #94
    Sep 2013
    California
    I can say nothing but thanks
  5. #95
    Jan 2010
    I haved working v5.0 (metal case) xprogm but when I programming some HC9S12 processors I have verify error.
    Well, yesterday I update ATmega64 with flash and eeprom from this post.
    And when switch fuses and LockBits like on this pictures i have "Device is silent" and XprogM is dead (RS232 and USB)
    But, when I enable Fuse "Watchdog" and program to Atmega64, my xprog is detected in program, but no any information and authorisations.
    Now i have no any authorisations and no any data in info (see pic).
    Please any help or ideas?
    Needs to program 93c46 ? 93c46 its only for USB connection?
    Regards
    SOLVED!!!
    My shitty ISP programmer (Propox ISPcable II) always program fuse "Boot reset vector enabled (default adress=$0000);[BOOTRST=0)", even if I unmark this fuse.
    I use other XprogM and all programmed ok.
    I need to buy a better ISP Programmer
    Regards
  6. #96
    Jul 2009
    israel
    hi
    any one have dump for x-prog 5.3 or 5.4
  7. #97
    spiridonas's Avatar
    Hi guys I try to update the firmware in the my clone xpog with edbl software 5.50 and after success update when run xprog 5.0 software says message device silent
    Please how I can to back again to previews state.
    I have and other original xprog but I can to reflash with this tool the atmega 64 from updated (damaged) clone xprog
  8. #98
    Jul 2013
    Thank you for all the info!
    So there're still no 5.4.5 or 5.4.8 dumps?
  9. #99
    heteromies
    Guest
    Please tell how to take dump, i can try?
  10. #100
    Apr 2013
    Poland
    Default image rescued Xprog programmer tl866a
    Hello,image rescued Xprog programmer tl866a
    the best thing is to set Fuse
    Fuse low byte:0x2F
    Fuse high byte:0xCA
    Extended fuse byte:0xFF
    Lock bit byte:0xEB
    To load both files together with the set Fuse byte
    sorry my english
  11. The Following User Says Thank You to maax990 For This Useful Post:
    ecufix (19th September, 2023)
  12. #101
    serg2000's Avatar
    Apr 2011
    Ukraine
    lock bits not correct
  13. #102
    Apr 2013
    Poland
    2 xprog program this lock bits,all work perfect
  14. #103
    Mar 2010
    UK
    My xprog-m clone which I had with dongle v5.3 had problem reading MPC processors, always got stuck on "initialising device". I downgraded to v5.0 without dongle and then it was working fine. Suddenly i started to get the "verify error" problem so i thought solution was to use dumps from 1st post in this thread. Since changing firmware to the one in the 1st post of this thread I can no longer read MPC561 as I always get "initialising device". I can read eeproms fine. I saved original eeprom data but (stupidly) forgot to save original flash data. Anyone able to shed some light pls?
    All options are authorized
    Last edited by looly; 13th March, 2014 at 01:43 PM. Reason: Additional info added.
  15. #104
    Jul 2013
    Just a note, you probably didn't get the correct data when you read the "original" eeprom/flash as it's protected (and the software checks that it's protected before continuing work).
  16. #105
    Mar 2010
    UK
    Quote Originally Posted by oxygenium View Post
    Thanks, I dont feel so much of a fool now .
    Any solutions pls?
