You can use this software to find maps, thanks to jazd.
http://www.digital-kaos.co.uk/forums...ection-287921/
hi there !
need some help in this !
car
fiesta 2009 1.4 tdci sid206 68cv
I was looking at the maps and can find proper factor"s for :
torque IQ/Nm
fuel map"s
boost
lambda
missing me map"s
rail limiter
boost limiter
boost X temperature
Injec X temperature !
if someone have made one of this please give a help !
I hope find more map"s and wend I have identified I put here!
ori file read width fgt2 2mb obd plug
thank"s in advance !
br
mexanico1971 (8th June, 2017)
use factors from other sid ecu's 803 206 etc
and also the one from ppd
ofsset may been diff?rent
mexanico1971 (19th July, 2013)
rail and boost limiters are easy to find
i think railpressure factor 0.0325520 if we have max. 1600bar $4DA2E 16x16
but i dont know if i am right!!
rail limiter?
maybe 8x8 map ? 4F48E 4F6B6 ? ?
some factor"s of sid 803/A
hpa = factor 0.082918
kg/h = factor 0.015625
?C = factor 1 offset -50
ms = factor 0.001
mg/stroke = factor 0.004 offset -131.072
nm = factor 0.031250
rpm = factor 32 or factor 1 (depending where it's used)
volt = factor 0.004883
Lambda = factor 0.19
Degrees = factor -0.023438 (for SOI offset = 120)
mg = factor 0.004 (some times using offset -131)
pedal = factor 0.097654
BOI
crankshaft degrees: factor 0.023438 / offset -120
Axis
X: ms/s 0.004
Y: RPM
but it look do no feet in sid206
my thank"s to smartuning
I stoled this from is post !
likenoother (5th July, 2016)
some are from ppd ...
so sometime you just need to change the offset ...
when they not fit generaly the offset is diff?rent
hi there !
I was try to mod some map"s but I think the editor have some bugs !
another thing
winols detect"s only a part of the map"s like 16X7 but I think some map"s are 16X16 correct ?!
like this one
and about the bug editor is this safe to flash ?!
i use winols 2.37 all my maps are ok
detected as siemens maps
