to backup an original game use a program called "raw dump" and an LG dvd reader drive
* LG-8164b
* LG-8163b
* LG-8162b
* LG-8161b
either model will work and will produce an iso file in about 3 hours
this then gives you an iso file, iso files can also be downloaded from various utorrent site
so which ever way you get your iso which is an image of the original disc you img burn at x1, as said up to x4 is ok but you will be 100% on a correct burn at x1
on average an image takes about 30 minutes to burn
once you have your backed up copy of your game (imagine you lost or erased the iso) you can then use img burn to create an image from the already backed up disc using a standard dvd drive
i say img burn as Nero can and does change the byte size and causes the disc to fail
