Good day members of DK
I have a audi A4 2005 1.8t with rb4 cluster. Dump was corrupted due to use of blue supervag. There was no def or error message on dispaly but the fuel reserve light stayed on the whole time. Tried to to sort it out with a repaired dump but did not work so I cloned I found another audi in my shop with the same software version etc and cloned the crypto part of the dump over to the problem vehicle and did a immo off in the ecu and car starts and cluster all works.
But the problem I have is that the yellow immo light is flashing the whole time and hazards are on the whole time. Meaning that the key is not matched to the cluster. I have tried to match the key with vcds and each time I try it comes up as error. I can not understand why it can not the key with cluster. I have tried with k-line chips , ID48, can etc but each time it is error.
Can any member please help me with this problem?
Many thanks in advance
