Page 3 of 4 FirstFirst 1234 LastLast
Results 31 to 45 of 46
Thread: nbox hd enigma2
  1. #31
    Default power-cut
    Quote Originally Posted by portbhoy View Post
    The reason they are half the price is that they have not been modified to run enigma 2 and is basically just a provider box unable to do anything else unless you can read polish and are really good with a soldering iron. As for it being a starter box, thats also a no go you need some knowledge of enigma 2 and oscam to set it up properly.
    hi portbhoy,it seems like you know a bit about these boxes,i had a power-cut last night and now i can't get any picture. sound is there,in info bar there is no resolution scale eg:1080,576,menu's all work etc. it happened once before,i just kept unplugging it from the wall and eventually i got picture back, so far i must have unplugged it about 20 times still no joy. any assistance would be appreciated, bearing in mind i know next to nothing about these boxes. cheers jim
  2. #32
    DK Veteran portbhoy's Avatar
    Sep 2008
    I would try a reflash it might simply have lost or corrupt a tuner driver.
  3. #33
    Jan 2013
    Just ordered one of these, hope I made the right decision! I really wanted a VU+ solo2 but the missus would not allow. I'm hoping this is a good compromise!
  4. #34
    Feb 2013
    anyone who has one of these you can actually run the image from the rear USB socket or better still run it from your hard drive!! Runs as sweet as from the HDD.
  5. #35
    DK Veteran psats's Avatar
    Sep 2008
    Quote Originally Posted by tomthered View Post
    Where is the how to.
  6. #36
    Feb 2013
    ]This can be done from within the Blue Panel.
    1st make a full backup image - takes around 30 minutes and FTP to your computer. Saved out my usb backup and loaded that back up into hdd on SDA1.
    Use the Disk Manager (inside Install Manager) to re partition your HDD - WARNING all data on sda (HDD) will be lost.
    Make 3 partitions.I made SDA1 is 1gb ext 3, SDA2 is 1gb swap file, SDA3 is rest of drive as ext3.
    Mount sda3 as HDD in Mount Center.
    FTP your full backup to media/hdd/
    From Install Manager choose SDA1 and your full backup then press red to install - this process takes just a few minutes.
    Boot from HDD
    Boot starts quicker than from USB and it runs stable for me.
    Booted into HDD1 and all setup. To configure Crossepg change HDD to the STA file that appears after you have setup the partitions. Then you need to redownload the EPG data from within the Crossepg configure file. Reboot through HDD1 and all set. Oscam worked from the start from backup.
    CoolTV working to after transferring picons, Very responsive to remote commands to.
  7. #37
    any links to where to buy from, seen ebay links page 1, but do i have to solder wires on, my eyes are not up to that now
    loading image not probelm, anyone tried a nbox single tuner model, could do with a replacement for my daughter trusty old dm500
  8. #38
    Feb 2013
    search for this number on ebay-171003263961. I bought mine from him and they come ready soldered, all you need to do is specify an image, I chose Nebula Zero v2 and thats the twin tuner model Nbox 5800sx. There is a 3 months guarantee on his work.
  9. The Following User Says Thank You to tomthered For This Useful Post:
    the goat (20th April, 2013)
  10. #39
    Dec 2012
    Hi Tom, I was just wondering, what do the different images actually do? whats the difference? I have been pointed in the direction of Enigma2 & came across this box on ebay, funnily its the exact one your describing by the same seller , and noticed he installs it with the 4 different images but unsure what one to actually get if I go for it, be a couple of minths til I get the moeny together though.
  11. #40
    Feb 2013
    I run Nebula Zero v2 which is very stable, there is a new one called Hyperion which is supposed to be good, no idea as mine is very stable and I can recommend that as an image.
  12. The Following User Says Thank You to tomthered For This Useful Post:
    gregg1978 (1st May, 2013)
  13. #41
    Mar 2009
    My dm800hd refuses to boot for the last 3 days, just stuck in boot loop and can even flash it so thinking of getting one of these boxes, just want to know can i run mgcamd 1.35 on these?
  14. #42
    Sep 2008
    Quote Originally Posted by androp View Post
    yes mgcamd 1.35 works fine but oscam better for recording and watching other
  15. #43
    Mar 2009
    Cheers thanks mate
    Sent from my HTC One X using Tapatalk 4
  16. #44
    Jul 2013
    i wouldnt get another nbox 5800sx they are crap you are better off getting a vu+ solo 2 receiver for the sake of a few more quid you can get a vu+ solo2 for about ?139 on ebay i have had nothing but problems with the nbox getting it is my biggest regret look how many problems people are having with them on the forums compared to the vu+
  17. #45
    Sep 2008
    Quote Originally Posted by vayen View Post
    The peeps that have problems with nbox its usualy down to the users.
    v4 hyperion run from usb perfect
