Results 1 to 6 of 6
Thread: 19.2
Hybrid View
    Jul 2011
    manchester
    Default 19.2
    hi, can someone please tell me, if i want to tune in to a new satallite say 19.2 do i have to clear my existing channel list (28.2) and upload a channel list for 19.2 thanks.
    Top Poster togznstyle's Avatar
    Dec 2012
    the moon
    Quote Originally Posted by sirrias View Post
    Just add a new list. But do you have a moveable dish if not you are stuck with 28.2 sorry
    Togz
    Never eat yellow snow
    Don't forget to thank me
    TOGZ
    Jul 2011
    manchester
    thanks for the reply ? just got a new dish 80cm with monoblock LNB, if i turn the dish in the direction of 19.2e will it not receive
    DK Veteran nibblitz's Avatar
    May 2010
    You dont need to clear 28.2e, just move your dish, then manually add the new satellite location into your box and then scan it for channels.. You wont get 28.2e anymore though until you move the dish back...
    What monoblock did you buy? A 6 degree one? If yes, you can point your dish at 19.2e and your box will be able to receive both 19.2e & 13e using diseqc settings on box...
    You could ditch the monoblock, stick 3 single LNB's on your Dish and use a diseqc switch, you could then have 28.2e, 19.2e and 13e...
    or
    Stick a motor on your dish, swap your monoblock for a single LNB, then you'll be able to get absolutely loads of satellites...
    Jul 2011
    manchester
    thanks for the info, i have a sly dish 28.2e so i have just put up a 80cm dish like you said on 19.2e and 13e waiting for diseqc switch to get here so hopefully i will get the three sats ?
    May 2010
    Dont think you'll be able to use your monoblock with a diseqc switch, a monoblock already has a diseqc switch built into it... You'll need to use 2 seperate LNB's on the 80cm dish if you want 19.2, 13e and 28.2e going down one feed from the diseqc switch to your box...
    You could actually put 3 lnb's on the 80cm dish and do away with the sky dish if you wanted...
