Any help appreciated, no RRD (phew) but when disc inserted xbox tries to read disc but nowt happening (2 years old). Microsoft say 3 year extended warranty only covers RRD! They want ?80 to repair anyone any clues to if this is a common problem/easy to sort. Am I just as well getting a new machine.
as stated i would probably spoof the drive over, just make sure you have your key and spoof the drives.
Just a thought what drive is it + is it flashed? does it read original games?
No the drive is original I have acquired another xbox that died with RRD so I will swap the drive etc. fingers crossed.
im having a similar issue! i acquired a flashed 360 from a friend, he had issues with rrod. i repaired rrod and went on to play it. it worked fine until i took my chances and installed the NXE! big mistake! any fixes?
Why not over heat your console and send it back for rrod? Then when you get it back say they damaged the drive coz its stopped working then they will have to fix it..long process but worth 80quid..make sure your console is genuine though..
Read the Rules here; they apply to EveryOne.
__________________________________________________
DM800s HDOpenbox S10
TM500
DM500s
90cm FortecStar dish
Technomate 2300 motor powered by UsalS
Try pot adjustment
here is a pot guide
?80 for a repair or ?30 for a new drive? Makes more sense to buy a new drive in my opinion.
I would try the pot adjustment 1st, if that fails then replace the drive.
