Results 1 to 4 of 4
    audiotek's Avatar
    May 2011
    Default Xprog-m 5.0 FTDI chip erase
    Hi, I need your help with my xprog-m clone (blue motherboard):
    I tried to repair my vagcom 11.2 cable with mprog 3.5 but I forget to disconnect the xprog-m and now my xprog-m clone is dead , now when connect the xprog-m appears like: "Ross-Tech Hex or USB Interface", the xprog-m and vagcom 11.2 have the same FTDI chip and I reprogramed the xprog-m by mistake with the file of vagcom cable.
    I need the .ept file for xprog-m FTDI chip, please help me. Thanks in advance...
    Xprog Box Original, UPA Original, GromCalcTool,TL866A, Carprog, Renesas H8SX,Obdstar X300DP, EZ500, CHIPSOFT MID, Vagcom Original, Witech OEM, Ford VCM II OEM, Mazda VCM II, Volvo Vida-Dice, Hyundai & Kia GDS, MUT III, Ford & Mazda VCX, TS401, Cardaq-m, VAS5054 Plus, JLR , Cardaq 3 Plus, Launch x431 Pro3, Renault Can Clip, VVDI prog, Autel iM608, GM DPS, CDA6, Nissan Ners, Consult III Plus, Techstream, Honda HDS and iHDS, MMC flasher, Mazda MDS, Forscan, HP Tuner, Miniprog.....
    audiotek's Avatar
    May 2011
    Problem solved, just loaded the default configuration.
    I had similar problem that i couldnt connect to ft chip using mprog as it showed random vid and pid so i simply removed eeprom chip near ftdi chip! then it turned to default configuration and xprog started working fine without eeprom.
    hi xprog 93cxx epp
  5. The Following 2 Users Say Thank You to emssado For This Useful Post:
    estwood68 (4th March, 2016), Sersergey (18th March, 2019)
