Results 1 to 10 of 10
    Jun 2011
    Default pls i need flash for ezs 211 545 23 08
    hello friends pls i have an ezs 211 545 23 08
    the ezs stopped working the customer say after communicating the car many time
    attached the flash file and the eeprom file of the ezs
    any one can help me with the flash file for it or can check my flash file if its damaged and repair it
    thanksAttachment 171543
    Last edited by elmaalouf; 24th April, 2013 at 06:51 AM. Reason: add missed attachement
    smayer's Avatar
    Jan 2012
    Quote Originally Posted by elmaalouf View Post
    where is the atached flash file?
    Here good flash
    Jun 2011
    thanks friend but i am trying to open ur file its fffff is there something wrong?
    and attachment added can u check my files pls
    smayer's Avatar
    Jan 2012
    What you use to read the flash??
    my file it's ok, write with xprog.
    Just select ms12-secured,
    i think you are wrong about mcu mask.
    Jun 2011
    Hello i am using r270 i tried tk open ur file also with x prog its ffffffffff
    Jun 2011
    Can u pls check my attached files if they are ok?
    Jun 2011
    help plsssss
    smayer's Avatar
    Jan 2012
    My file it's 100% ok. write with xprog. Use editor a see it's not all FF.
    Jun 2011
    thanks verry much i will try and report but i know ur infos are correct every time thankss
    Default HELP
    WHATS DIFFERNCE BETWWEN SELECTING 9S12DG128 AND 9S12 SECURED IN XPROG M SOFT ?
