thank you very much,works OK![]()
Here is some info to do mask numbers 1M84E and 1L15Y. Ecu is SID803.
Press thanks if this helps you.![]()
angelx431 (30th October, 2018), Boggdan (5th February, 2018), brodaty (12th April, 2017), CARPARTS (12th March, 2018), cfgebel (3rd September, 2014), constan (18th January, 2021), dikdom (2nd March, 2017), DjRomeoR (17th June, 2015), eagleone-two (16th March, 2016), Faraday (25th June, 2015), gifo (22nd January, 2024), jenya (14th October, 2022), M3L3R (9th March, 2017), Przemo1972 (20th July, 2017), rafalkama (16th March, 2021), script1234 (23rd June, 2022), whiskymk (10th June, 2019)
Hi I need synchro please
ABS ID 000000044666
Hello Does Codecard "solution" works for all Ecus???
I have read SID803A are not compatible....
SID803 WORKS OK.
You can see above where data are stored.
Thanks for your opinion.
i needed original files from a volvo CEM with 2 mcu 1M84E, i corrupted the flash files,
Can you help syncro me with the ABS please?
ABS-ID: 00 00 00 11 11 64
Hi, Please can you help me to synch ecu and CEM Volvo S40 SID803
I change old ABS and car won't to start. Old ABS burned.
ABS ID:000000056020
ECU: SID803
EEPROM: 1K79X
Please help me
Hi , try and report Toutancamon
Toutancamon (7th February, 2017)
Hi, thank's I try it and i send you report last time.
Hi, m232 dump don't work, car won't crank
thank's
Hi , try this
Toutancamon (10th February, 2017)
Please help to synch ECU SID803A and CEM 9s12 Volvo V50
thanks!
ABS ID: 000000197528
volvo_V50_sinch.rar
hi , Don't work again
Help please
Thanks lupu work fine
