Results 1 to 7 of 7
    motorsportsz's Avatar
    Jun 2012
    Default FORD FOCUS FUELLING PROBLEM? DPF REMOVED
    Hi there
    i have a customers 2006 ford focus 1.6tdci 110bhp model.
    Customer had removed and gave it in to me for the delete & remap.
    At times the car would smoke in first and second gear. smokes pretty bad. black smoke.
    The car would also cut off at times and won't start back up for a while.
    whilst cut off the car gives the following diagnostic codes.
    P1927 & P193, both fuel additive codes.
    I have attached the file of the tuning and dpf delete.
    what could be the problem? I'm assuming its a leaking injector or fuel pump issue. however, i have been told the cars dpf fluid sensor has to be disconnected from the dpf fluid? I can't see no sensors, only a pipe.
    Cheers
    mbtun's Avatar
    May 2012
    Europe
    faulty injector! common problem with 1.6tdci
    the problem is ecusafe or volta
    Babos's Avatar
    Mar 2012
    back orig file and do diagnostic!
    and what tool you use for this job?
    maybe after writing ecu lost injection codes who need renew
    Oct 2012
    If this guy make BDM copy,nothing hard restore lost injector codes,only rewrite eeprom.
    If he need recode injector codes with diagnostic tool!
    codes are here
    Jun 2012
    Quote Originally Posted by ominimicu View Post
    ecusafe wasn't used
    Quote Originally Posted by Babos View Post
    i used galletto mini
    cheers
    Jun 2012
    Quote Originally Posted by mbtun View Post
    i am also assuming it is a faulty injector
