Results 1 to 5 of 5
    Jan 2013
    Default pls help newbie :)
    I have a dm800 dreambox with nemesis installed. i tried using dcc for the first time (connection type : router) user: root password: dreambox. the network is ok but i have the following problem
    Telnet Connected
    FTP Connected
    Bootmanager: not found.
    Telnet Disconnected
    Telnet login incorrect!
    i tried numerous ftp clients but no joy
    i need the user/pass as my sub. just expired
    anyhelp pls
    Jan 2009
    Quote Originally Posted by batuflu View Post
    Telnet Connected
    FTP Connected
    Telnet Disconnected
    anyhelp pls
    best best is reflash with dreamup, then fully update box, then it will default to root/dreambox
    Jan 2013
    thanks for your update.
    i require to update the cccam.cfg...
    i am not keen to flash d dreambox
    is there an easier way to update the cccam.cfg file? maybe from webcontrol? or some sort of remote control ediiting??
    thanks once again
    Aug 2011
    There is a really easy way to edit your cfg file.
    Google Dreambox Cccam editor
    This will give you several forums where you can Download the program which is simple to use.
    Goodluck
    Aus
    merseyside
    if you bought the box with a sub pre-programmed then the seller may have changed the default user/password
    as above a reflash will restore these to default but the tuner and epg etc will need re-configuring
