Results 1 to 7 of 7
    Dec 2012
    Default VU + Duo 1TB internal HDD problem
    Hello Everyone,
    I am running blackhole 1.7.5 and its been fine for a week. I have a 1TB internal HDD fitted and I have the Cool TV Guide installed.
    I have setup my EPG using Crossepg. Its been working fine using the HDD to store all the EPG data. Over the last day my EPG data is missing and I have tried to download again. But when I check the Crossepg settings my storage device has changed form HDD to Internal Flash. I cannot change it back and if I go to devices the hard disk is not shown and it searches for the device but crashes. After a restart the HDD is available again and everything is fine.. What will be causing the HDD to vanish?
    Is this a know problem with this image or with the clone boxes?
    The box and HDD are less than 6 weeks old.
    DK Veteran tomhick024's Avatar
    Dec 2008
    Between a Rock and a Hard Place
    Use a usb stick to save your epg to as it keeps waking up hardrive every time you change chanell. mine used to crash as well.
    Need to set destination to usb on epg settings..
    Whatever!!
    Dec 2012
    What size usb stick would you use? Its strange because I purchased the same Box and hard disk for my mate. His was setup with the same image which was backed up from mine and his is fine. Mine seems to loose the mount point. I initialised the drive using blackhole..
    Mar 2009
    why dont you try a different image like open vix or open pli
    Dec 2012
    Here is my crash report if anyone can take a look it would be appreciated?
    <?xml version="1.0" encoding="utf-8"?>
    <opendreambox>
    <enigma2>
    <crashdate>Wed Jan 30 00:40:23 2013</crashdate>
    <compiledate>Jun 1 2012</compiledate>
    <contactemail>crashlog</contactemail>
    <!-- Please email this crashlog to above address -->
    <skin>skin.xml</skin>
    <sourcedate>Jun 1 2012</sourcedate>
    <branch>vuplus_experimental</branch>
    <rev></rev>
    <version></version>
    </enigma2>
    <image>
    <dreamboxmodel>dm500hd</dreamboxmodel>
    <kernelcmdline>bmem=112M ubi.mtd=0 root=ubi0:rootfs rootfstype=ubifs rw rootflags=sync</kernelcmdline>
    <nimsockets>NIM Socket 0:</nimsockets>
    <imageversion>
    <![CDATA[
    version=1000201206010023
    comment=Vuplus
    target=9
    creator=OpenEmbedded <oe@vuplus.com>
    url=http://www.vuplus.com/
    catalog=http://www.vuplus.com/
    </imageversion>
    <imageissue>
    <![CDATA[
    Vuplus 2.2.0 + BlackHole 1.7.5 %h
    </imageissue>
    </image>
    <software>
    <enigma2software>
    <!-- Cannot allocate memory -->
    </enigma2software>
    <dreamboxsoftware>
    </dreamboxsoftware>
    <gstreamersoftware>
    </gstreamersoftware>
    </software>
    <crashlogs>
    <enigma2crashlog>
    <![CDATA[
    e: play, vpid=-1, apid=-1
    DEMUX_STOP - pcr - ok
    AUDIO_STOP - ok
    DEMUX_STOP - audio - ok
    AUDIO_CONTINUE - ok
    start release channel timer
    not pauseable.
    RemovePopup, id = ZapError
    [eDVBCAService] remove channel 0x75a70388
    [eDVBLocalTimerHandler] remove channel 0x75a70388
    [eEPGCache] remove channel 0x75a70388
    allocate channel.. 0802:0002
    [eDVBCAService] new channel 0x20c1710!
    (0)tune
    RotorCmd ffffffff, lastRotorCmd ffffffff
    prepare_sat System 1 Freq 10847000 Pol 1 SR 23000000 INV 2 FEC 2 orbpos 282 system 1 modulation 2 pilot 2, rolloff 1
    tuning to 1097 mhz
    OURSTATE: tuning
    allocate Channel: res 0
    [eDVBCIInterfaces] addPMTHandler 1:0:19:1B1D:802:2:11A0000:0:0:0:
    allocate demux
    resolve: resolve ${sysconfdir}/scan_tp_valid_check.py
    resolve: -> /etc/scan_tp_valid_check.py
    [CrossEPG_Wrapper] -> SAVE
    [SEC] set static current limiting
    [SEC] invalidate current switch params
    set sequence pos 3
    [SEC] setTone 0
    [SEC] sleep 10ms
    [CrossEPG_Wrapper] <- START
    [SEC] update current switch params
    [SEC] startTuneTimeout 5000
    [SEC] setFrontend 1
    setting frontend 0
    [SEC] sleep 500ms
    (0)fe event: status 0, inversion off, m_tuning 1
    BlackHoleapi: popclose,
    (0)fe event: status 1f, inversion on, m_tuning 2
    OURSTATE: ok
    [eDVBCAService] channel 0x20c1710 running
    [eDVBLocalTimerHandler] channel 0x20c1710 running
    no version filtering
    0014: 70 00 00 00 00 00
    mask: fc 00 00 00 00 00
    mode: 00 00 00 00 00 00
    [eEPGCache] channel 0x20c1710 running
    [EPGC] next update in 58 min
    stop release channel timer
    0012: 4e 1b 1d 00 00 00
    mask: ff ff ff 00 00 00
    ok ... now we start!!
    0000: 00 00 00 00 00 00
    mask: ff 00 00 00 00 00
    eventNewProgramInfo 0 0
    have 1 video stream(s) (1518), and 1 audio stream(s) (151a), and the pcr pid is 1518, and the text pid is 151b
    allocate demux
    disable teletext subtitles
    decoder state: play, vpid=5400, apid=5402
    DMX_SET_PES_FILTER(0x1518) - pcr - ok
    DEMUX_START - pcr - ok
    DMX_SET_PES_FILTER(0x151a) - audio - ok
    DEMUX_START - audio - ok
    AUDIO_SET_BYPASS(1) - ok
    AUDIO_PAUSE - ok
    AUDIO_PLAY - ok
    Video Device: /dev/dvb/adapter0/video0
    demux device: /dev/dvb/adapter0/demux0
    VIDEO_SET_STREAMTYPE 1 - ok
    DMX_SET_PES_FILTER(0x1518) - video - ok
    DEMUX_START - video - ok
    VIDEO_FREEZE - ok
    VIDEO_PLAY - ok
    DMX_SET_PES_FILTER(0x151b) - ttx - ok
    DEMUX_START - ttx - ok
    VIDEO_SLOWMOTION(0) - ok
    VIDEO_FAST_FORWARD(0) - ok
    VIDEO_CONTINUE - ok
    AUDIO_CONTINUE - ok
    not pauseable.
    [AutoRes] service changed
    + 1/1 TID 00
    done!
    PATready
    use pmtpid 0104 for service_id 1b1d
    0104: 02 1b 1d 00 00 00
    doing version filtering
    0000: 00 00 00 07 00 00
    mask: ff 00 00 3f 00 00
    mode: 00 00 00 3e 00 00
    VIDEO_GET_EVENT - ok
    [AutoRes] got event evVideoSizeChanged
    [AutoRes] got event evVideoProgressiveChanged
    + 1/1 TID 02
    done!
    have 1 video stream(s) (1518), and 2 audio stream(s) (151a, 1519), and the pcr pid is 1518, and the text pid is 151b
    [eDVBCAService] new service 1:0:19:1B1D:802:2:11A0000:0:0:0:
    [eDVBCAService] add demux 0 to slot 0 service 1:0:19:1B1D:802:2:11A0000:0:0:0:
    [eDVBCIInterfaces] gotPMT
    demux 0 mask 01 prevhash 00000000
    [eDVBCAService] send 119 bytes
    9f 80 32 73 03 1b 1d 09 00 13 01 81 08 01 1a 00 00 08 02 00 02 82 02 01 00 84 02 01 04 1b 15 18 00 00 03 15 1a 00 00 06 15 1b 00 00 0b 0f 06 00 00 0b 0f 07 00 00 0b 0f 09 00 00 06 15 1c 00 00 05 0f 00 00 00 05 0f 01 00 00 05 0f 02 00 00 05 0f 03 00 00 05 0f 04 00 00 05 09 11 00 00 05 09 12 00 00 05 09 13 00 00 06 15 19 00 00 05 09 19 00 00 05 09 1a 00 00
    0104: 02 1b 1d 09 00 00
    mask: ff ff ff 3f 00 00
    [SEC] set dynamic current limiting
    +- 1/2 TID 4e
    ++ 2/2 TID 4e
    done!
    0012: 4e 1b 1d 33 00 00
    [CrossEPG_Wrapper] <- END
    [CrossEPG_Wrapper] -> CLOSE
    [CrossEPG_Wrapper] -> QUIT
    [CrossEPG_Wrapper] <- OK
    sdt update done!
    child has terminated
    pipes closed
    poll: unhandled POLLERR/HUP/NVAL for fd 59(16)
    Looking for embedded skin
    [CrossEPG_Wrapper] executing /usr/crossepg/crossepg_dbconverter -r -d /media/hdd/crossepg
    [AutoRes] determineContent
    [CrossEPG_Wrapper] <- READY
    [CrossEPG_Wrapper] -> EPGDAT /media/hdd/crossepg/ext.epg.dat
    [CrossEPG_Wrapper] -> LAMEDB /etc/enigma2/lamedb
    [CrossEPG_Wrapper] -> CONVERT
    Start timeshift!
    recording to /media/hdd//timeshift.GGMwz0
    before: 1
    after: 1
    setIoPrio realtime level 7 ok
    FILEPUSH THREAD START
    [EITSave] query epg event id 58239, 1:0:19:1B1D:802:2:11A0000:0:0:0:
    [EITSave] found event.. store to disc
    [eDVBLocalTimerHandler] diff is 0
    [eDVBLocalTimerHandler] diff < 120 .. use Transponder Time
    [eDVBLocalTimerHandler] not changed
    [CrossEPG_Auto] poll
    [CrossEPG_Loader] patch epgcache.load() found
    [CrossEPG_Loader] /usr/crossepg/crossepg_epgcopy /media/hdd/crossepg/ext.epg.dat /media/hdd/epg.dat
    main thread is non-idle! display spinner!
    [EPGC] 125487 events read from /media/hdd/epg.dat
    [EPGC] start cleanloop
    [EPGC] stop cleanloop
    [EPGC] 6489160 bytes for cache used
    no ancillary data in audio stream... abort radiotext pes parser
    pipes closed
    poll: unhandled POLLERR/HUP/NVAL for fd 56(16)
    action -> WizardActions back
    allocating new converter!
    reused converter!
    [Picload] setPara max-X=50 max-Y=30 aspect_ratio=1.000000 cache=0 resize=1 bg=#00000000
    [Picload] decode picture... /usr/share/enigma2/picon/1_0_19_1B1D_802_2_11A0000_0_0_0.png
    [Picload] decode picture... /usr/share/enigma2/picon/1_0_1_189E_7FD_2_11A0000_0_0_0.png
    [Picload] decode picture... /usr/share/enigma2/picon/1_0_19_2710_801_2_11A0000_0_0_0.png
    [Picload] decode picture... /usr/share/enigma2/picon/1_0_19_52D0_814_2_11A0000_0_0_0.png
    [Picload] decode picture... /usr/share/enigma2/picon/1_0_19_F12_7ED_2_11A0000_0_0_0.png
    [Picload] decode picture... /usr/share/enigma2/picon/1_0_19_1B1C_802_2_11A0000_0_0_0.png
    [Picload] decode picture... /usr/share/enigma2/picon/1_0_19_F15_7F1_2_11A0000_0_0_0.png
    [Picload] decode picture... /usr/share/enigma2/picon/1_0_1_57B_7E5_2_11A0000_0_0_0.png
    [Picload] decode picture... /usr/share/enigma2/picon/1_0_1_1290_7EA_2_11A0000_0_0_0.png
    [Picload] decode picture... /usr/share/enigma2/picon/1_0_19_F0D_7F1_2_11A0000_0_0_0.png
    [Picload] decode picture... /usr/share/enigma2/picon/1_0_1_585_966_2_11A0000_0_0_0.png
    [Picload] decode picture... /usr/share/enigma2/picon/1_0_19_F1A_7D5_2_11A0000_0_0_0.png
    [Picload] decode picture... /usr/share/enigma2/picon/1_0_1_1793_7EE_2_11A0000_0_0_0.png
    [Picload] decode picture... /usr/share/enigma2/picon/1_0_1_178E_968_2_11A0000_0_0_0.png
    action -> OkCancelActions cancel
    action -> InfobarShowHideActions hide
    [EPGC] 6489124 bytes for cache used
    It's now Wed Jan 30 00:31:47 2013
    [timer.py] next activation: 1359506007 (in 99998 ms)
    next real activation is Wed Jan 30 22:09:40 2013
    [timer.py] next activation: 1359506007 (in 99996 ms)
    It's now Wed Jan 30 00:33:27 2013
    [timer.py] next activation: 1359506107 (in 99999 ms)
    [timer.py] next activation: 1359506107 (in 99996 ms)
    nr_read 909 nr_write 1435
    sum 2344 prev_sum 0
    hdd was accessed since previous check!
    [IDLE] 0 3600 False
    It's now Wed Jan 30 00:35:07 2013
    [timer.py] next activation: 1359506207 (in 99997 ms)
    [timer.py] next activation: 1359506207 (in 99996 ms)
    [EPGC] 6488400 bytes for cache used
    It's now Wed Jan 30 00:36:47 2013
    [timer.py] next activation: 1359506307 (in 99997 ms)
    [timer.py] next activation: 1359506307 (in 99996 ms)
    action -> InfobarMenuActions mainMenu
    loading mainmenu XML...
    TimerEdit TimerEditList
    PluginBrowser PluginBrowser
    reused converter!
    reused converter!
    reused converter!
    reused converter!
    action -> OkCancelActions ok
    okbuttonClick
    Ci CiSelection
    ParentalControlSetup ParentalControlSetup
    reused converter!
    reused converter!
    reused converter!
    okbuttonClick
    Ci CiSelection
    reused converter!
    reused converter!
    reused converter!
    okbuttonClick
    reused converter!
    reused converter!
    reused converter!
    action -> SetupActions ok
    reused converter!
    reused converter!
    reused converter!
    warning, skin is missing element key_yellow in <class 'Plugins.SystemPlugins.CrossEPG.crossepg_setup.Cro ssEPG_Setup'>
    warning, skin is missing element key_blue in <class 'Plugins.SystemPlugins.CrossEPG.crossepg_setup.Cro ssEPG_Setup'>
    warning, skin is missing element key_green in <class 'Plugins.SystemPlugins.CrossEPG.crossepg_setup.Cro ssEPG_Setup'>
    action -> SetupActions right
    It's now Wed Jan 30 00:38:27 2013
    [timer.py] next activation: 1359506407 (in 99997 ms)
    [timer.py] next activation: 1359506407 (in 99996 ms)
    It's now Wed Jan 30 00:40:07 2013
    [timer.py] next activation: 1359506507 (in 99995 ms)
    [timer.py] next activation: 1359506507 (in 99993 ms)
    action -> SetupActions cancel
    nr_read 977 nr_write 3396
    sum 4373 prev_sum 2344
    [IDLE] 0 3600 False
    action -> MsgBoxActions cancel
    action -> InfobarExtensions DeliteBpshow
    reused converter!
    reused converter!
    reused converter!
    reused converter!
    action -> ColorActions blue
    reused converter!
    reused converter!
    reused converter!
    action -> WizardActions ok
    reused converter!
    reused converter!
    reused converter!
    Traceback (most recent call last):
    File "/usr/lib/enigma2/python/Blackhole/BhSettings.py", line 692, in updateList2
    IOError: [Errno 2] No such file or directory: '/tmp/ninfo2'
    (PyObject_CallObject(<bound method DeliteDevicesPanel.updateList2 of <class 'Blackhole.BhSettings.DeliteDevicesPanel'>>,()) failed)
    getResolvedKey config.plugins.crashlogautosubmit.sendAnonCrashlog failed !! (Typo??)
    resolve: resolve ${sysconfdir}/enigma2/settings
    resolve: -> /etc/enigma2/settings
    getResolvedKey config.plugins.crashlogautosubmit.addNetwork failed !! (Typo??)
    getResolvedKey config.plugins.crashlogautosubmit.addWlan failed !! (Typo??)
    </enigma2crashlog>
    <pythonMD5sum>
    </pythonMD5sum>
    </crashlogs>
    </opendreambox>
    Dec 2012
    Hello, blueflash234
    I have tried a Vix image but ended up going back to Blackhole I have never tried PLI image. Is it any good?
    Dec 2012
    Found a fix on another forum..
    Latest files for CrossEPG reverting to internal and randomly failing to load
    Was asked for the latest files as the respective threads have got way too large that they are difficult to find so here they are
    These files haven't changed since they were last posted in their respective threads so if your CrossEPG is working fine then there's no need to update as the files haven't been updated
    All 3 files should be unzipped/unrared to the folder /usr/lib/enigma2/python/Plugins/systemPlugins/CrossEPG, delete the corresponding .pyo file and then restart the box.
    To check that the revised files are in place, after the restart check that the 3 .pyo files have a date/time stamp the corresponds to roughly the reboot time.
    In terms of what the files do:
    crossepg_auto.py - this looks like the main library file that gets called when the box does an automatic EPG download and import
    crossepg_setup.py - this is the main library file that gets called when you invoke the crossepg setup menu on screen
    crossepg_loader.py - this library file performs the actual import of the latest EPG data.
    So I have gone into my box using FTP to the directory listed above and deleted the 3 files then I have unzipped the files attached and copied them to my box in the same folder listed above. I restarted the box and checked that the new files had today time and date stamp.
    I will test this over the next week fingers crossed!
