torq I think is $0D32E 18X1
you got to look in 16 bits mode !
Hi!
I have a golf 3 with old EDC ECU 2x 27c512
please help me to find more maps in this dump.
I found:
-Driver wish 0741A
-DW inverted 07822
-Turbo 07BE0
-Smoke limiter 07620
-pump voltage 07224
-EGR 07863
I want to know Torque limiter, Boost limiter and SVBL and other infos about this 8 bit dump. Are there any offsets for the maps? Because this is very strange for me I mean values are 0-255.
This is my first old EDC.
My work is my life ART TECH GARAGE
sorry !
it"s just one file !
I joint the two files, and it just 64k once at is time !
that"s why I can get no ecu data !
now I see
0281001309
$6996 torq in eprom 1 not shore now about it !
the other you want, I can see it quickly got to search careful !
the other eprom n?2 got some diferent map"s , so you got to check because I think inje??o and boost are in diferent eprons !
I check boost and it seems ok !
and other ones you sayd
I never see one like this before to !
good luck
Thank you! I think torque limiter is good but need factors....
If I increase the IQ the RPM is increasing too.... Why?
I use old factor 001 and get +/- 46mg/h !
because I think 36mg is few !
also find other TL in eprom 2 in $D32E !
I have read what banza say"s but I do not have shore of that !
maybe TL control"s regulat fuel valve or other thing that control RPM !
did you log vagcom to see aprox fuel delivery ?!
BR
good luck
No I didn't log VCDS. I'm just learning this file because I didn't see like this before.
