Results 1 to 8 of 8
    Member j4ru's Avatar
    Default Audi A6 2007 2.7TDI (132kw) DPF remove
    I need help to remove DPF.
    AUDI A6 2007 2.7TDI EDC16 . Ecusafe & Volta no good solution.
    Ecusafe - don't work.
    Volta - Whole DTC Table removed.
    Any one can make good solution (only dpf off , DTC table not removed ) pls ...
    Many THX
    j4ru
    i have file from mine audi a6 2.7 tdi originaly no dpf if you need i can give you
    Jun 2012
    La Coru?a - Spain
    Hi.
    Test this one and report
    Nice day
    Camilo.
  4. The Following User Says Thank You to camil For This Useful Post:
    vwcc (3rd June, 2016)
    Hi, try this, Manually switched off and all dtc active - tested solution
    Report back!
    password only by pm dont forget pusch thanks and reputation
    Quote Originally Posted by camil View Post
    Hi.
    Nice day
    Camilo.
    Quote Originally Posted by chucky69 View Post
    Report back!
    Quote Originally Posted by scary View Post
    (before writing i change dpf for new ( soot to 0 ) off course )
    Thanks for everyone but all dumps alternates :
    2 Faults
    049921 - Software Incompatibility with Engine Control Module
    U0301 - 003 - - MIL ON
    U0301 - 002 - - MIL ON
    Jun 2012
    unplug (2) temp sensor.......
  9. The Following User Says Thank You to macxlulu666 For This Useful Post:
    cosmin cl (27th February, 2016)
  10. #8
    Quote Originally Posted by macxlulu666 View Post
    Thanks, i was solve problem. We need to unplug upstreem temp. sensor and diff sensor. Downstreem temp. sens. we can keep pluged.
    Thank You for all suggestion.
    In best regards
  11. The Following 2 Users Say Thank You to j4ru For This Useful Post:
    Boeing747 (23rd December, 2013), cosmin cl (27th February, 2016)
