Page 3 of 5 FirstFirst 12345 LastLast
Results 31 to 45 of 63
Thread: RCD500 MP3 CODE
  1. #31
    Bulgaria
    Quote Originally Posted by m3mpower View Post
    Which one? the one full of 000?
    Or $15C-00!!! ?
    try this:.......................................
    for my is ok!
  2. The Following User Says Thank You to bogege For This Useful Post:
    m3mpower (9th November, 2013)
  3. #32
    Spain
    I will try this tomorrow, because i must desolder the eeprom again and resolder it to try if this works..
    I will let you know
    thanks for your help
  4. #33
    Spain
    Quote Originally Posted by bogege View Post
    for my is ok!
    Hello
    I tried this one and it's the same problem, still asking for code...
  5. #34
    Faraday's Avatar
    May 2012
    The dark side of the moon
    If you read mcu then I can provide code from dump
  6. #35
    Spain
    Quote Originally Posted by Faraday View Post
    Thank you, but i can't read the MCU, i don't have the programmer for it
  7. #36
    Faraday's Avatar
    May 2012
    I have attached the dump from S93C76
    Now I see your dump byte swap
  8. The Following User Says Thank You to Faraday For This Useful Post:
    bogege (10th November, 2013)
  9. #37
    Spain
    sorry, I don't understand your post ??
  10. #38
    Faraday's Avatar
    May 2012
    in your dump all bytes swapped
  11. #39
    Faraday's Avatar
    May 2012
    compare with this: rcd500.jpg
  12. The Following 2 Users Say Thank You to Faraday For This Useful Post:
    mariantv (31st January, 2018), maxi12 (19th May, 2016)
  13. #40
    Spain
    I know, I have swapped bytes and it's the same problem
  14. #41
    Faraday's Avatar
    May 2012
  15. The Following User Says Thank You to Faraday For This Useful Post:
    m3mpower (15th November, 2013)
  16. #42
    Spain
    OK thanks, i will try it later, hopefully it will work
  17. #43
    Spain
    This link does not work, it opens a page with Error 404...
    Can you please upload the file again?
    Thank you
  18. #44
    Faraday's Avatar
    May 2012
  19. The Following User Says Thank You to Faraday For This Useful Post:
    m3mpower (26th November, 2013)
  20. #45
    Spain
    I have programmed the chip with your dump, and the problem is still there, the unit is still asking for the code.
    Is there another solution?
