Hello
Today I have a problem, car Suzuki Grand Vitara 1.9 DDiS 2007.
An error has occurred P0486 Exhaust Gas Recirculation Sensor B Circuit
EGR and cleaned was about one day but the next day the same. Does anyone EGR pinout to check voltage. Regards
Hello
After the cleanup, as time passed until the error again go back?
Or error returned immediately?
I can help you but only if you want me to help you
All the questions should start from what car, what year, what engine is what fuel. What are the symptoms of the problem. Only then is what you know, what fault code, live data, what you have done.
Only the other day returned an error. On the same day I rode and everything was all right. What I noticed is that the freeze frames of the temperature was 70 degrees Celsius. And the car just started.
What is the egr B Circuit.
why i asked that this error not rely related to wiring, maybe sometimes
70 it is coolant? that import for egr
is there any symptoms after a cold start and idling or driving?
Sometimes, but rarely fires worse.
Apart from that, everything ok
A lot of egrs can be cleaned up so they function correctly but there is a position switch which signals back egr valve position to ecu; this potentiometer type switch wears out & wrong signal brings up fault codes of high & low voltage range, even though all is fine. That is why many manufacturers recommend not cleaning & replacement only of egr's
i had somebody here he has buyed a new egr the power is back but the code still remain
hello have u solved the problem ?
i have same in car
p0486
p0403
p0405 or 9
egr is new
i think that the dpf can be the problem , difference presure = 10mbar
