Results 1 to 8 of 8
    Jan 2009
    Default Skybox f3 glitching help please
    I'm getting a lot of picture freeze and then sync issues on movie channels. I have tried the following. Reset box and router. Turn off time shift. Set output to 1080i instead of 1080p. Flash different firmware and ch list. Anything I'm missing here? I'm assured the line is good! Cheers
    V.I.P. Member mdt's Avatar
    Feb 2009
    bolton, north-west. uk
    Quote Originally Posted by madonion View Post
    ping your bb line... if the ping is good its your provider,regards mdt
    DM800HDSE SIM 2.10. SSL84D OPEN-ATV ORBITAL 80CM/DARK MOTOR/IBU/53E-30W
    Jan 2009
    Pinged the line - it's fine!
    Sep 2008
    what bb are you with and curious if you have a superhub?
    Jan 2009
    Vm and superhub
    Apr 2013
    Quote Originally Posted by cactikid View Post
    Curious with your question re:superhub? I have superhub and as mentioned in another post I have started to get glitching over the past few days! To add to this - I have 2 skyboxs set up one is hardwired to superhub and 2nd is wireless. Not an issue with provider as I know others with this provider with different boxes and they have no issues.
    DK Veteran mahrkpat's Avatar
    Jun 2012
    Quote Originally Posted by digitalsingh View Post
    There are lot of reports about problems with VM super hub just google it.
    Sep 2008
    some have added a wifi router in between box hub and plugged their lan cables into that and switched off crappy wifi on the hub and it brings up your signal.
