Edc16c31 is 1mb,c35 is 2mb....
I read the same car by mppsv12 and file is 1mb.not write yet...
use bdm100, xprog M or somthing else, MPPS is to risik for this ECU
Fgtech2 working good on this ecu's i done couple of them but must use battery booster to get 13-14v
will go on to write modified file without problems MPPS? it confuses anyone tried it? Reading is probably alright .... I attach the file reading orig
ECU EDC16C31
dvdpgn (2nd January, 2016)
well, and someone tried to write the same ECU with MPPSV12? I do not want anything to go wrong when writing
I not trust MPPS he brick 1 ecu.
i try only 1 time and in this first time i brick ecu.
I had no problems writing 1mb file on this car. I had other car jacked to have the enough V btw
Use bdm100 on this to be safe, i killed one of these while trying to write it with mpps12 clone.
It is still easy to repair with bdm even if the flash failes and you dont have any backup.
Just remember that an mpps read is not a full dump of 29bl802c flash, it just does partial read and fills inn with empty data to make it 1mb in size like a full dump would be.
If you need 1mb that file software send me pm
