Results 1 to 5 of 5
    Mar 2009
    London
    Default Need advice on setting up lmb t o 3 satellites
    Hi can someone tell me if I can get universal lmb holder which can be set to Astra 4.8 Hotbird 13 and Astra2 28.2. I am using TD110 dish.any advice is much appreciated.Thanks
    Nov 2008
    Quote Originally Posted by andriusv View Post
    you can buy the triax 4 lnb holder for your td110 dish, and move the individual lnb holders along the rack to where you need them to be
    add an lnb into each holder, and use a 4 way diseqc switch to switch between them
    Mar 2009
    London
    Thanks. I am looking on eBay they all are from 3 to 20 degrees. Do I still can get on astra 28.2e
    Nov 2008
    it may do , or may not , the 5e is going to be a struggle but thats your fault for wanting such a wide spread , a motor would be a better bet
    digicon's Avatar
    You will get the 4.8? east European beam as this can be picked up on a standard 43cm dish but forget the Nordic beam on that kind of spread as ramjet so rightly states.
    you would have to make 13? east your centre with 4.8? & 28.2? as your offsets.
