catalinosonesti (26th November, 2021)
Arduino doesn't receive any data from radio.
You have bad connection between arduino and pin 2 of connector at back of the radio.
Measure resistance between Atmega328P pin 30 and pin 2 of connector at back of the radio.
It should be about 1000 Ohm or less when jumper is in normal mode.
Check connection on the bottom side of arduino pcb.
I will send you e-mail with high resolution foto. It might help you.
I mesure and you know i have 2 Boards Arduino 1 with 5v rezistor i have 0 ohm.
Second with parallel 2 rezistor i have only 220 ohm.
I must by original Board?
Regrads
It might be any arduino Nano, cheapest clones should works.
It should work if you have 220 Ohm or 0 Ohm. This resistances has protection function I think. Maybe they are diffrent on diffrent arduino clones but I don't think so.
I see on your video that program hanging because it waits for data frame on pin 30 (RX) of Atmega328p.
It must be connection between pin 2 on radio and pin 30 on Atmega328P.
catalinosonesti (27th November, 2021), ganson (27th November, 2021)
mbi thank for info!!! I made code finder - works. Only the limit of 30 codes is not pleasant.
mbi (27th November, 2021)
What im doing today , i put RX pin to 2 back of the radio and work .....till 3 atemps .
I make a short video , radio stop after 3 try and disconect from power .
when i try again same movie. https://imgur.com/a/KAiG6No
What can be ?
Sorry to say but it looks like my program is not working with your radio software version.
I attached new version (flash), program Atmega328 again and you can try it but I don't know if it will work.
Please send me what is your radio SW and HW version and production date from sticker.
Anydraj (3rd November, 2022), catalinosonesti (28th November, 2021)
Hi .
I try today with New Flash how send to me , but same result, no even jump to 0001.
I put Foto with sticker from radio.
Best regrads
mbi (28th November, 2021)
catalinosonesti (29th November, 2021)
Thx .
I know the code , from the navi , but i make this project below MBI Poland and for me is strange because locks like Martech .
For me is wery intresting , and i have time to try till i make it .
Regrads
catalinosonesti (28th November, 2021), Decode Ghost (28th November, 2021)
Hi.
again, if not read try downgrading to Windows older versions
Hi.
you are using win10 win11 or win8 downgrade this version to win7, try process
