Page 1 of 4 1234 LastLast
Results 1 to 15 of 58
    Dec 2011
    Nottingham
    Default Citroen C3 HDI Non Start No Communication ECU
    Hi All,
    I have a Citroen C3 UK 57 2008 1.4 HDI non start problem. I have connected Lexia and it communicates with everything but not injection (ECU). Fault code stored in the BSI is no communication with ECU (which I imagine is the main fault). When I try to start there is nothing. Checked the transponder, all the fuses. and they are ok.
    So my questions are:
    Which wire is the communication from BSI to ECU?
    Is the main BSI under the hood (966405580) or the one behind glove box (9659285480)?
    Is this ECU a common failure? Is there any repair guides?
    Thank you in advance.
    genius76's Avatar
    Dec 2012
    Lowestoft
    engine code? and full foult codes
    I can help you but only if you want me to help you
    All the questions should start from what car, what year, what engine is what fuel. What are the symptoms of the problem. Only then is what you know, what fault code, live data, what you have done.
    racin-snake's Avatar
    Jun 2009
    BSI in the glovebox
    BM34 under bonnet
    can you com with abs and eps ?
    and checked the maxi fuses under the bm34
    Today is the Tomorrow you worried about yesterday ......Was it worth it ?
    Dec 2011
    Nottingham
    8HZ (DV4TD)
    genius76's Avatar
    Dec 2012
    Lowestoft
    FAULT CODES?
  6. The Following 2 Users Say Thank You to genius76 For This Useful Post:
    gcelettronica (23rd February, 2022), sep382 (3rd August, 2019)
  7. #6
    Dec 2011
    Nottingham
    I've checked the maxi fuses they are fine. When I do a global test I get dialogue with ABS and EPS but when I try to go in to them I have no comms......looks like we are getting somewhere!
  8. #7
    busaman's Avatar
    Sep 2009
    suffolk uk
    abs and bm34 give trouble on these link the can wires on the abs if all comes back abs is the problem.
    7.31sec@203.3mph
  9. #8
    Dec 2011
    Nottingham
    Fault codes:
    BSI
    Illumination of 3rd brake lamp open circuit
    No communication with engine management ecu
    Instrument Panel
    Remote fault
    Permanent fault
    Engine Speed Information
    Switch module under steering wheel no comms
    Multifunction Screen
    Permanent Fault
    Absence f +permanent on display
    That's all the codes
  10. #9
    Dec 2011
    Nottingham
    When you say link the can wires, what do you exactly mean mate?
  11. #10
    busaman's Avatar
    Sep 2009
    suffolk uk
    there are two wires goin in two coming out unplug the abs and link the twisted pairs do you have a wiring diagram.
    7.31sec@203.3mph
  12. #11
    DK Veteran rachmach's Avatar
    Jan 2011
    Workshop
    chek power of ecu or try with another.
  13. #12
    Dec 2011
    Nottingham
    Yes I've got the diagram. I thought that's what you meant. I'll try in the morning and report. Thanks mate
  14. #13
    Dunker's Avatar
    Yorkshire
    First of all strip the covering from the wires that go to the plugs on the ECU. Find out which are the power feeds (and earths). Give the power feed wires a good pull and see if any break. The wires on these nails tend to break inside their plastic coverings just outside the ECU (usually within a few inches). Alternatively, open ECU and check power feeds at the pins on the PCB with what you should be expecting. Sounds like one 12v will be missing.
    V Series TMS470 / EEPROM data - encryption / decryption, totally pwned.
    IEC 62056-21 - new discussion: sonsivri.to/forum/index.php?topic=60412.0
  15. #14
    Apr 2010
    I had this once before! Problem was BSI. I to could communicate with BSI. And all seemed to be ok! With it.
  16. #15
    busaman's Avatar
    Sep 2009
    suffolk uk
    ive tapped the bsi with a hammer handle before now and everything works for a while (stuck relay ) give it a try.
    7.31sec@203.3mph
  17. The Following User Says Thank You to busaman For This Useful Post:
    Meat-Head (20th July, 2018)
