Page 6 of 18 FirstFirst 123456789101116 ... LastLast
Results 76 to 90 of 261
  1. #76
    Top Poster benzerrouki's Avatar
    Algeria
    Thanks scary you are the champion,you are the one.
  2. #77
    scarymistake's Avatar
    Apr 2009
    Europe EN
    Update V7.14
  3. The Following 4 Users Say Thank You to scarymistake For This Useful Post:
    paro44 (31st May, 2013), shirokov (24th July, 2013), super-cab (31st May, 2013), xilophene (30th May, 2013)
  4. #78
    hello,
    Or you can buy quality interface please thank you
  5. #79
    Apr 2009
    Europe EN
    Update V7.15
  6. The Following 9 Users Say Thank You to scarymistake For This Useful Post:
    esse (6th June, 2013), immokill (1st May, 2014), kitty-hawk (6th June, 2013), looking77 (12th June, 2013), mattydr67 (5th June, 2013), paro44 (6th June, 2013), shirokov (24th July, 2013), super-cab (7th June, 2013), xilophene (5th June, 2013)
  7. #80
    May 2013
    hello scary, you didn't have the update 7.13 to 7.15 ? it's directly 7.11 to 7.15 thx for you're awesome work
  8. #81
    Germany
    Hi guys!
    The DiagBox seems to be working fine with my interface, but if I choose to run the PP2000 instead (from the DiagBox menu) the error screen appears saying that the PP2000 can not run because either the interface is not connected to the USB or it's been used by another application.
    I assume it is because the interface is flashed with a DiagBox compatible firmware, and in order to run the PP2000 I need to downgrade the interface firmware.
    Would that be correct, or there might be some other problem causing the PP2000 not to run?
    Thanks.
  9. #82
    Oct 2008
    On Earth
    Dosen't matter mate
    If you have 7.13 allready installed to upgrade to 7.15 use the 7.11 to 7.15 upgrade
    Don't worry all included and it is not a problem
    Good luck
  10. #83
    May 2013
    it's works, thx for you're help bro
  11. #84
    hello
    This site they wind material quality?
    Most professinal and reliable OBD tool, auto diagnotice tool supplier in China
    Thank you for your response
  12. #85
    Oct 2008
    On Earth
    I don't know what kind of tools they sell mate. But what I can tell you is that the PSA XS Evolution tool from China it isn't flashed.
    Even they sell it and it "works" with DiagBox version 6.xx
    Because their softwear have a blocked firmwear upgrade
    If you cannot upgrade the firmwear you can do everything with the softwear
    If you upgrade the firmwear that will not works well because the tool it has a blacklisted serial in the new firmwears
    So think about this. But you can buy a good tool from China and if you want to be able to use it with newer version of Diagox after v5.29 you need to flash it
    But about this we dicussed many times
    Good luck
  13. #86
    Top Poster xilophene's Avatar
    Dec 2010
    Quote Originally Posted by delta43 View Post
    hello
    This is shit !!
    "2. It compatible with most Peugeot cars from 1995, but it can not work well with Peugeot 307 after 2004 year."
    no diagbox
  14. #87
    hello
    Or buy then the good PSA interface
    thank you
  15. #88
    Apr 2009
    Europe EN
    Update V7.16
    not yet tested
  16. The Following 8 Users Say Thank You to scarymistake For This Useful Post:
    DiagNost46 (5th July, 2013), hotty01 (23rd August, 2013), kitty-hawk (20th June, 2013), paro44 (21st June, 2013), shirokov (24th July, 2013), super-cab (23rd June, 2013), xilophene (20th June, 2013), yellowstilo (30th June, 2013)
  17. #89
    Apr 2009
    Europe EN
    Update 7.18
    In first post
  18. The Following 7 Users Say Thank You to scarymistake For This Useful Post:
    elpaolace (16th July, 2013), immokill (1st May, 2014), kitty-hawk (16th July, 2013), paro44 (16th July, 2013), shirokov (24th July, 2013), xilophene (16th July, 2013), Zmann (16th July, 2013)
  19. #90
