Results 1 to 8 of 8
    Jan 2009
    Default cdf file for digivox
    My son has a digivox but has lost some channels is it possible to download the cdf file from my eurovox max onto his.
    thanks in advance
    May 2008
    England
    hi
    if you live in the same province then yes that shhould be no problem - he should be able to view the same channels and will also get the same channel setup you have....
    Sep 2008
    dont think u should try it as it is a different box and u might brick it,delete non working channels and rescan again should bring them back.
    May 2008
    England
    sorry my mistake i thought u had the same box
    Jan 2009
    cheers to you all ill just flash and rescan
    cheers
    Sep 2008
    why does everybody flash when they lose channels.at most factory reset 0000 to delete,power off at back for 30secs/on autoscan ur provider with splitters removed ,and emu to on,exit out.
    Jan 2009
    sorry cactikid forgot to mention he was manually entering codes
    Sep 2008
    Quote Originally Posted by dochol3460 View Post
    well then a good idea is to update firmware so no manual input needed.
