Results 1 to 15 of 18
    Default range rover 1996 28c16 oki caLCULATION HELP NEEDED
    HELLO FRIEND I NEED HELP TO CALCULATE RANGEROVER 1996 DASH WITH EEPROM 28C16 OKI TACHOSOFT IS WRONG WITH THE CALCULATION THX IN PREVIOUSE CURRENT KM IS 203600
    I NEED TO CALCULATE INTO 204700 THX AGAIN
    what kind of calculator i must use?
    bmwparts's Avatar
    RSA (where men are men and sheep are nervous)
    Quote Originally Posted by gselectric View Post
    Try this. Uses a simple system if you compare the two files you will see what I mean. Tachsoft has the solution as well. Dont forget to remove the chip from the board and plug the cluster back into the car to clear mileage on body control unit.
    If things seem under control, you are simply just not going fast enough!!
    i will try and report in 20 minutes thx
    it shows me wrong reading i just tryed it any help\?
    bmwparts's Avatar
    What reading did it show?
    honingkoning's Avatar
    Dessert
    What programmer do you use on this chip.
    And tachosoft should be ok, i used it in the past once , very easy algo.
    Regards Adam.
    captain crackers's Avatar
    england
    If you do the job correctly ie. desolder the eeprom, re-fit the cluster without the eeprom and start the engine for about 30 seconds to be sure, then re-solder the eeprom after programming it with the attached dump, you will have 204,700 kms. Arthur.
    Prussia
    ze kapitan knows his stoof on ze olde army truks
    england
    It would appear that our friend gselectric needs supreme accuracy as bmwparts gave him a good dump but not 204,700 kms. It was 204,800 kms. Close but no cigar. Arthur.
    thx for helping my friend i think not the dump is the problem after i made this all procedures i put the dash back and i made no mistakes some kind of smoke went out it was like cursed i and unreadable reading has came out i will have the car after tomorow back wish me good luck to find the problem
    U.S.A
    " some kind of smoke went out"....from where ? instrument cluster ?
  13. #13
    Prussia
    Quote Originally Posted by maumaumau View Post
    I think that was maybe a programmer called Smok?
    [mind you, probably the best result for an old RR, up in smoke]
    seriously, If someone is not sure how to do a job, its madness to proceed without at least asking on here for a quick run through of the correct procedure.
    pity the smoke wasnt mentioned in post no. 5.
  14. #14
    yes from instrument cluster my problem was i put the 28c16 in wrong position it is my first time mistake i never do such things usually but the eeprom still reading and writing
  15. #15
    Nov 2011
    Quote Originally Posted by captain crackers View Post
    .. this was the predicted smoke from Captain Crackers cigar ?
