Page 1 of 4 1234 LastLast
Results 1 to 15 of 52
    blackpirate's Avatar
    Jun 2009
    Default DPF and Lambda Remove tests
    yo guys
    testers needes to this softwares!
    Please post some files to test!
    my guess its that software are crap!!!
    P.S: DO NOT USE FILES ON CARS! MIGHT KILL IT!
    so preferably experienced tunners to test files!!
    Thank you
    If freedom is outlawed, only outlaws will have freedom!!!!
    assitutto's Avatar
    May 2009
    Milano, Italy
    A5 3.0tdi edc17cp04
    i defap this car today
    mod this file if you want and i check that work
    Jun 2009
    Quote Originally Posted by assitutto View Post
    A5 3.0tdi edc17cp04
    sw supports only cp14
    gives error on your file!(and send mail to authors)
    thnx! u have any other file?
    assitutto's Avatar
    May 2009
    Milano, Italy
    i'm full of file
    this is audi a4 2.0tdi cp14
    Jun 2009
    Map1 has been disabled
    Map2 has been disabled
    Map3 has been disabled
    Map4 has been disabled
    Map5 has been disabled
    can you check?
    thnx
    assitutto's Avatar
    May 2009
    Milano, Italy
    file is not good.
    sw starts to change addresses too early
    assitutto's Avatar
    May 2009
    Milano, Italy
    you want other file for test?
    what ecu file you need?
    Jun 2009
    file is not good.
    but changes are good???????
    even if it starts ealier!? changes are ok??
    look on image! and if you have files that are supported pls send!
    lambda files also ok to send!
    thank you
    imcumen's Avatar
    Feb 2009
    FRANCE
    audiA4 edc16U31
    assitutto's Avatar
    May 2009
    Milano, Italy
    Quote Originally Posted by blackpirate View Post
    yes, change are ok
    upload edc16c39 alfa, edc16c34 ford and 500 1.3mjet fiat
    Jun 2009
    Quote Originally Posted by imcumen View Post
    audiA4 edc16U31
    pls look carefully on image and see supported files!!!
    Jun 2009
    EDC16C39 (JTDA) (2MB) Detected OK.
    12 Maps are detected and modified.
    fiat not supported! pls see again if values are ok but on wrong addreses! if same its crack fault!!!!
    thank you very much
  13. #13
    assitutto's Avatar
    May 2009
    Milano, Italy
    edc16cp3 audi don't exist
    audi have edc16u31 and edc16u34 and edc16cp34
  14. #14
    Jun 2009
    on sw cp3/34
  15. #15
    Meat-Head's Avatar
    why remove lambarda it helps the fuel mixture be correct
    you will either wear out engine or use lots more fuel.
