Page 3 of 4 FirstFirst 1234 LastLast
Results 31 to 45 of 52
  1. #31
    blackpirate's Avatar
    Jun 2009
    Quote Originally Posted by Preliator View Post
    Every lamer (so called some crackers) can understand this, software using same protection like EGR Remover software. If you don't using original software, your file will be patched to wrong adresses. So, crap not software. Here are crap unbrain (only loader, ollydebug script user lamers)
    I have lambda software and my testing files working good. Also i have sharing here some resulting files (all is confirmed by DK users, you can look my old messages).
    I don't buy DPF software yet (no money ) But my friends using and i don't hear any problem.
    Finally,, i think another bad (crap) cracking story here....
    mate, take it easy! before makeing someone idiot , look at what i said and what this thread its all about!!!!
    thats i was trying to find out, crack problem or original!
    on some files patched wrong addreses with good changes!- bad crack
    but what about doing just craps on file? that from crack also??
    if you have origininal post lmbda file org and done with your org sw, i post with cracked and see if are identical! that will be helpfull!
    thank you very much
    If freedom is outlawed, only outlaws will have freedom!!!!
  2. #32
    Member Preliator's Avatar
    Mar 2012
    Thread about, bad crack and blamed to software + developer. Sorry but least for me, this not justice. Here are peoples think software bad(?). But software working and license passing don't enough for full (original) working. Developer making more protections for against pirate using. I was talking this before with asc guys.
    Of course, we can try here test files. Nobody against this. But if you write here " software bad, can damaged your ecu's" with bad crack software, this not justice.
    (I was tested Alwarez's EGR shared crap and differents was big. Original software and loader version really different working. This are security and normal.)
    First you must show to me your testing software original or loader version. If you testing with loader version, test result always unsafe. You can't blame software or developer because firstly your crack is bad. We was see this before EGR remover subject. I'm still using EGR Remover v1.52 and my %90 files working perfectly on cars.
    Other side, of course some peoples wanted to sell every peoples EGR + DPF manuel (one) files. Like these softwares making to all automatical. I understand these business peoples problems with ready softwares 1 file 100 usd or 150 usd. But software just 350 usd. Easy to understand some things.
    Nice Days,
  3. #33
    Jun 2009
    lets do it crystal clear!
    on first post i said people post files and i solve with cracked! on the thing: not put on car, i was telling that cracked sw result not ok and might kill ecu!!!
    and i was not tellg full sw its crap!! i said my guess!
    guees means unsure!!!!
    so, post a file done with org and 100% that work on car(tested), i try with cracked and see results!!!
  4. #34
    Meat-Head's Avatar
    Quote Originally Posted by wiseman View Post
    For removing the post cat lambda if you have stainless system fitted with no cat in it. If you take cat out in car leave sensor fitted mil light comes on
    ON AND OFF TOPIC:-
    P0420 - cat below effiecency
    1) Easy way to to search Emerican sites for "sparkplug extenders"
    a bit of tube with thread at each end, spaces sparkplug away from combustion chamber - stops engine burning oil??!!?? Insert one of these after the cat - screw lamdba into it
    2) TYpe in google 'Emerican ford mustang sad owners club mil elimnator"
    you will find a capacitor and resistor wired into the second sensor to fool the system - any cat/car
    MUCH better than programming it out.
  5. #35
    Nov 2009
    celje, slovenia
    Quote Originally Posted by Meat-Head View Post
    ON AND OFF TOPIC:-
    meaty tell us more about rear o2 sensors emulators.
    do you have any diagram for it, exactly how to wire it
  6. #36
    Feb 2013
    Default mercedes sprinter 518
    hi
    i have the following Mercedes sprinter edc 16
    please need speed limiter and DPF and do I have to remove the error after that
  7. #37
    Nio's Avatar
    Mar 2010
    Hello BP, post software you think not good and i'll test it for you. Regards.
  8. #38
    Jun 2010
    "... more about rear o2 sensors emulators."
    Something like that.
    Regards.
  9. The Following User Says Thank You to 8k65m For This Useful Post:
    mexanico1971 (23rd December, 2013)
  10. #39
    Oct 2012
    Quote Originally Posted by 8k65m View Post
    Regards.
    It work but not for all engines
  11. #40
    Jun 2009
    Guys, who has original sw post a file done on it and you tested on car and worked!!!!!!!!!!
    thank you
  12. #41
    Jun 2009
    nobody???????
  13. #42
    hello BP, can you remove lambda from golf5 1.6fsi MED9.5.10, please
  14. #43
    Dec 2012
    citroen c4 2009
    Bosch 0 261 S05 626
    96 669 342 80
    MEV17.4
    try to remove post cat lambda.
  15. #44
    Stanton's Avatar
    Dec 2010
    UK
    Im assuming post cat lamda is what's being played with here.
  16. #45
    Dec 2012
    Quote Originally Posted by Stanton View Post
    Of course...
