Results 1 to 11 of 11
    Dec 2010
    United Kingdom
    Default Help with LEXIA 3 installation please.....
    Can someone explain me to a couple of things.
    I installed LEXIA 3 and then PEUGEOT PLANET
    The whole process went ok and took 1 hour.
    I then installed diagbox V05.02, as soon as it installed LEXIA 3 and PP erased from my desktop???? is this normal? or is something wrong? has it kind of combined both softwares into one? (diagbox?).
    Secondly, i tried to activate diagbox with the patch. It said successful when i run patch, but when i activate manually i get error. Now the patch says ERROR if i click it. And when trying to activate diagbox the profile stays 00000000 and i cannot change it?
    Is there a way to delete the profile stored somewhere to retry? Should i use customer ID from what i used in lexia3 + pp2000?
    HELP!
    Dec 2010
    United Kingdom
    Does anyone have teamviewer so you can take a look?
    DK Veteran rachmach's Avatar
    Jan 2011
    Workshop
    whene you install diagnbox is normal lexia and pp2000 desinstalled .
    you must active your profil with 2FFFFFFF
    Dec 2010
    United Kingdom
    Quote Originally Posted by rachmach View Post
    That profile does not work...
    also tried 1FFFFFFF and 02FFFFFF
    Nothing works.
    DK Veteran Larue's Avatar
    Jan 2010
    Somerset, UK
    Quote Originally Posted by j4g3d View Post
    Nothing works.
    First of all uninstall everything related to Diagbox, PP2000 and Lexia, Then go to drive C and delete folders APP and APPLIC(you might need to close some related processes with Task manager), then open regedit and delete Actia folder and Firebird folder.
    Restart computer and start from scratch.
    Feb 2010
    Exactly must remove previous versions. All files, I replaced the entire system. Yeah I like you.
    Dec 2010
    United Kingdom
    Tried this but no luck. Spent so many hours. Diagbox does not activate at all. I will not ever try again as it does not work.
    Does anyone know what LEXIA can do?????????????
    1. what is lexia 3? citroen? if so upto what year it work on? v47
    2. Peugeot planet what year it work on?
    3. whats the reason to install diagbox if both lexia3 and pp is working fine????
    4. What is proxia3? how to install it? no information online at all!
    Nov 2008
    Croatia
    From my own experience:
    Diagbox is the best solution if you think use Peugeot and Citroen on the same PC.
    Proxia is good for older Citroen. I have a V38 and I think that has models until 2008. Installation is simple. Crack is not required. There are also schemes that can be used with Proxia.
    Jan 2012
    it is pain to install this lexia3 i have spend a week messing around with it .done it on the end ,think using same profile as pp. but don't see much difference comparing using pp2000 on its own.
    DK Veteran tapiru's Avatar
    Jan 2010
    my only thought is why you try install this programs if you not even know what they are and how to use them ?
    if you wish have success install a fresh XP SP3 and start your installation , but or DiagBox,or Lexia&PP2000
    no chance have all together in same machine , only if you have multy booth system
    By other side if you have a non flashed clone interface you cannot use DiagBox just with v5.0 up to 5.29 update
    good luck
  11. #11
    Jan 2013
    When you work with older cars (sorry, I cannot say exact years), then use PP2000 for Peugeot, or Lexia for Citroen.
    These programs are much faster than Diagbox.
    If something doesn't work with PP2000/Lexia, then use Diagbox. It is very much slower, but has newer cars in it.
    Unless your interface is modified in hardware ("flashed") before or after you bought it, you should not go higher than Diagbox 5.29
    When installing Diagbox, any existing installation of PP2000/Lexia are automatically uninstalled, because Diagbox brings its own little versions of these.
    When it doesn't install correctly, you might want to try installing on a completely fresh Windows XP.
    -> I recommend to stay with PP2000/Lexia, as long as everything works with your car, because it is not of recent model years.
