Results 1 to 8 of 8
Thread: record
    Feb 2013
    Default record
    hi
    I have skybox f5 anyone know if you can record while watching a different channel, if you can how do you do it.
    I think the answer is no I cant, if that is the case why have I 2 lnb inputs, 1 I think says loop.
    regards
    Dec 2010
    Norn Iron
    No you can't one is for lnb input other is loop out its used to connect another box with a run of cable.
    Feb 2013
    ok thanks for the help.
    regards
    Feb 2013
    as stated , loop out is for running another box ....but not recommended for many reasons....
    Best bet would be to add another stb , and use one for watching and the other for recording....Many ppl have/use more than one box ....
    BPG~
    Feb 2013
    hi
    is it possible I get a dual tuner receiver ?
    regards
    Dec 2012
    Quote Originally Posted by Bigpineguy View Post
    BPG~
    Why is it not recommended?
    DK Veteran nibblitz's Avatar
    Quote Originally Posted by jagandeep View Post
    The signal from the Loop out is cut when the Openbox/Skybox is powered on, any box connected via the Loop out will lose its signal until the Skybox/Openbox is powered down again...
    Quote Originally Posted by carpy47 View Post
    hi
    regards
    Not a cheap Skybox or Openbox... There are other makes of receivers with dual tuners, but they cost considerably more...
