Anyone?????
Anyone?????
never done with piasini
i do cmdflash over obd
piasini you need to make solder wires in the ecu ...
and make bridges ...
Everything work good Procesor sh7059, piassini read/write perfect, but slow.
Can you post pinout's connections ?
Im here to help and to be helped
One use to connect only pinout to power +12V and GND (-), second one its from piassini to connect wire on board. From menu you must select SHXXXX ToolBox / ToolBox [9].
immooff (20th October, 2015)
I have the same car.. but at mine , pcb is diferent ... look at picture . I have read it - ok , but when i wanted to write the modified file , i didnt have where to do the bridge
[QUOTE = luiggii79; 2735693] resolvido por problema de escrita neste ecu ?. Eu tenho o mesmo problema com você! por favor me ajude. [/ QUOTE]
I also have the same problem how to solve?
thank you
