Page 15 of 140 FirstFirst ... 510111213141516171819202565115 ... LastLast
Results 211 to 225 of 2097
Thread: kess v2 clone
  1. #211
    Jun 2012
    Default KEss v2 testing 1.94 original software
    Quote Originally Posted by moky View Post
    For help files it's normal that work you can download them without interface so..and here nobody updated kess djdanny.. as i see only ktag and after 0000000000 and dead as i say you..you are the first tester..........
    I tested Read, with 1.94.
    result:
    Opel Astra H 1.9 Diesel
    EDC16+C39 Read.
    Attached file!
    Please check, good, or not good file reading....
    Best regards!
  2. #212
    moky's Avatar
    Behind you
    Your file seems to be good
  3. #213
    Senior Member mauronow's Avatar
    Sep 2012
    Today I did a test in a Ford Ranger 2.3 16 V petrol
    When I click on this error ID. wake up error
    for that matter?? I happened to other cars too.
  4. #214
    Quote Originally Posted by mauronow View Post
    Error on desk?
    today i read BMW 335i K Line...1 hour and all right :-)
  5. #215
    Sep 2012
    Quote Originally Posted by djbiugi View Post
    Error on desk? because today i read BMW 335i K Line...1 hour and all right :-)
    I do not understand what you say, you understand my problem?
  6. #216
    Sorry...i change my words.....you try by OBD port? how much HP ?
  7. #217
    Sep 2012
    yes. obd2 port.. with error . the vehicle is original. 143 cv mof 2009
  8. #218
    How much Horse Power? Year ?
  9. #219
    Sep 2012
    in the previous post is the information of the engine.
    you have to connect to the internet to download the help files??? nothing happens? no blocking. ?
  10. #220
    moky's Avatar
    Behind you
    you install last sw kess on another laptop,download help files and transfert them on your laptop without connect..C:/Ksuite/Help)
  11. The Following User Says Thank You to moky For This Useful Post:
    mauronow (23rd April, 2013)
  12. #221
    Apr 2012
    Wonderland
    same error appear on ori kess v2 on some old EEV Ford ecu. The only way is remove flash and use a eprom programmer
    ProTuner since 1999
  13. The Following User Says Thank You to atomiczen For This Useful Post:
    mauronow (24th April, 2013)
  14. #222
    Apr 2012
    Wonderland
    tested today on BMW 320d 163hp edc16c35 read and write ok
    ProTuner since 1999
  15. The Following User Says Thank You to atomiczen For This Useful Post:
  16. #223
    Sep 2012
    thank you very much atomiczen!!. anyone know if it works so tricore??? resistance must be added??? tried it?
  17. #224
    Yaroslavl
    tested bmw dde 4 , dde626 full , mev946 full , me9.2 work ok
  18. #225
    Sep 2012
    Quote Originally Posted by flint77 View Post
    soft 1.84 ??? you have resistance soldier to fix bootmode ? or not ?
