About Bmw motorrad? Have you try Moky and Mauronow?
but kess v2 1.89 have driver in soft for unlock ecu 1.6 tdi wv ,or can read and write only?
pcr 2.1 ok on official since 1.88 so we must test.
Ok When arrived me kess v2 i try in this ecu!
i test today in ford focus tddi 1.8 90cv id ok, but not read.....error in change protocol...aghghgh
28F200 must be desolder...original galletto too have problem with TDDi...with TDCi Delphi no problem
clone kess,for cars,in obd work same as original
wiski (26th April, 2013)
hi moky....you a tested in other cars today ????
seems to work well this clone ...! want to know if doing well with tricore? I fear I have to try ....
....resistance weld today and copy the new files to the Sd. now I want to test if it works
I?m very interested in tricore too...
tested today edc16c2 mercedes read and write ok
the only little problem found on obd read is on marelli iaw 4af fiat, after reading fan always on, also with ignition off and car don't start. i have to disconnect battery and then connect again. car then start.
ProTuner since 1999
garagetech (5th May, 2013), mauronow (26th April, 2013)
i'm try to test an edc17c46 vag tricore now
i'll let you know
ProTuner since 1999
tested now edc17cp14, the one that i cannot read some days ago (p151 protocol)
now work perfect, read and write ok in tricore bootmode
ProTuner since 1999
atomiczen ......thanks for you report..!! works well with tricore then???
is it safe?
atomiczen ......You a soldier the resister in pcb ??? 100 k ? write the new files en the micro SD ???
thanks !
