igornorro (16th July, 2013)
Ok. The next week I'll try to get a picture of the original slave. Morgano probably could provide you a picture of the clone unit.
We will see if it is not poured with glue to avoid manipulation and study of the unit.
hello friends
i want to buy kess v2 slave original with protocole car/bike but i have some questions.
the software is limited or not?
if it is limited ,How long does it will stays ?
and How much does it cost to reactivate it ?
regards
I tried to write an original sw to an ecu (Bosch) with kess v2 clone today but was unable to do so with a message "security code is not ready" or something to do with security code. Does any one know what is this? any help would be appreciated
Hi BBturbo - we will try to help you but say what model Ecu - you are tried to read/write - model , sw and hw number , more info .
This info can help and other gays to help you .
Hi overs0ull, thanks. details are (bosch):
HW: 0261S04158
SW: 1037390399
Ver.HW: 07641003
SW upg: 07582788
Installation: MED172 INT FLASH
the file in the car is poorly tuned. I managed to get another similar sw which i was told is an original. tried to flash without success. the security code error came up. Just trying to find out what the error means.
Make it on bench
Hi it's not an error but is tprot , how is say the didi_du - make it on the bench on boot mode , and you not go na have problems .
Write what is happened after that are is fine .
security code error come up on T-Prot ecu when try to flash by obd
work ok on bootmode and tprot protocol
ProTuner since 1999
thanks everyone for the advise and help. Just for information sake, I managed to read the ecu but not write. I will try to bench flash it.
BTW not sure if this information is helpful.. I bought the kess v2 clone last month. I asked about the counter limit and this is their reply;
About
Kess V2, the item can support more than 500 times before. but now i heard from manufacture that, the item do not have such problem, the item we sent you is new one.
I don't know man are it true that .
All of the people here have counters problem i think and we will have it but have the solution now .
Today i receive my kess v2 clone and i am happy , now i only need to make the little changes to work with edc 17 and med 17 and all well be fine , i hope so when i read or write some of the i will write here what i happened .
