I have read/write Audi A4 2008 2,0tdi Quattro today. Bosch edc16
No problem
No problem
I have R/W Audi A3 2,0TFSI 2005 Bosch MED 9.1 no problem!![]()
Friend I need immooff to A4 with MED9.1 readed flash but it can read eeprom, any idea?
You need BDM read, flash+eeprom
Kess V2 clone can`t connect to Citroen Jumper 2012 180hp EDC17CP52 (Infineon Tricore TC1797) Bosch 0281018291 / 51912094 by OBD
I try`d to open and read Tricore and connect to Kess V2 but my ECU is not presented /not correct pitures as my ECU
EDC17CP52 is not listed...
(Ktag can read Tricore perfect, Eeprom and Maps)
morfej (26th February, 2016)
Today I try to read Citroen Berlingo 2012 1,6HDI 90hp EDC17C10 Tricore TC1797 but Kess V2 clone can`t get ID /read/write on this ECU
(Ktag can do this ECU Backup/maps/Eeprom)
today arrived new micro for my clone, that now work again
so solution for counter is definitely into the nxp micro.
ProTuner since 1999
euroscan1 (10th September, 2013), mexanico1971 (8th August, 2013)
I thing the counter is there again but is not big deal - it cost 20 bucks , and i wait 2 mcu to arrive next weekend . If kess is lock - change it and run again . For 30$ whit shipping and 50 flashes it's fair![]()
I don't thing they will remove the counter , or they can cause need to make money from something else .![]()
Chinese lithe people
micro have the counter active as the clone they sell, so there's 30 flashes every micro used.
desolder and solder again a 208pin micro is a pain in the ass. i don't think the pcb can tolerate more than 2 times this stress....
i'm working on a usb flasher for this micro, so there's no need to weld anythings....
ProTuner since 1999
someone tested kess on delphi dcm 3.5 Peugeot ? thanks
Just tested, kess work fine on psa rcz 2.0hdi 163hp delphi dcm 3.5 R/W ok
euroscan1 (10th September, 2013), mexanico1971 (10th August, 2013)
