Page 49 of 140 FirstFirst ... 3944454647484950515253545999 ... LastLast
Results 721 to 735 of 2097
Thread: kess v2 clone
  1. #721
    overs0ull's Avatar
    Nov 2012
    near the sea ... ;)
    Hi mate after changing the kess v2 cpu - did you make something else - like reinstall software or other thing , or just change the CPU and kess run again .
    After few flashes i will need to make the some thing for that i ask .
    "Chiptorque"- say what is happened whit the file writing with Kess v2 .
  2. #722
    Junior Member MiH's Avatar
    Slovakia
    Hi, I only replaced CPU without any other things.
  3. #723
    Jun 2013
    EU
    @MiH
    Do you know which parts are missing with the oki chip in the clone kess? I already got a oki chip to fit in, but there are many missing parts around it, and guess under it too before solder to pcb possiby 2x 4k7 resistors.
    Thanks.
  4. #724
    DK Veteran chiptorque's Avatar
    Nov 2010
    apparently does not record the File in EDC17. Operating system crashes and does nothing. loads the File to record and stuck windows XP.
  5. #725
    overs0ull's Avatar
    Nov 2012
    near the sea ... ;)
    this sounds sucks , but you can write it on boot-mode , or the laptop is not powerful as crashing for that i use very strongly laptop only for kess v2 and galleto v54 and AVDI cause they load the computer . Or sometime the windows just crashing .
    About the OKI chip that sound interesting , but i don't know were supposed to be ,lest someone say ho have it or know where need to be ,and if is not secret from where you get it .
  6. #726
    Jun 2013
    EU
    Buying m6636b oki chip can be done at ebay.
    There is only one place where it can go in pcb, but not only oki chip missing, many companion parts for the chip are missing too, resistors, capacitors, transistors, and quartz.
    We need to know specs of the missing parts to buy and fit them.
    Regards,
  7. #727
    Oct 2011
    Usa
    I'm working on that, arrived today OKI chip!
    Just dont know if the quartz is the standard value like in datasheet
    Somebody have the original Kess that can check for DK friends?
  8. #728
    Apr 2012
    Wonderland
    Quote Originally Posted by jmcartec View Post
    jmcartec, you pmbox is full
    ProTuner since 1999
  9. #729
    Apr 2012
    Wonderland
    Quote Originally Posted by chiptorque View Post
    sounds like a c++ library missing
    ProTuner since 1999
  10. #730
    Oct 2011
    Usa
    Hi atomiczen my pm box now is empty
  11. #731
    Senior Member mauronow's Avatar
    Sep 2012
    Hello. So you can not stop the counter? You can upgrade to the latest version the software. ? (1.93)
  12. #732
    Dec 2012
    any tested as ktag clone working with Bosch me9.7 mercedes
  13. #733
    Sep 2012
    Quote Originally Posted by overs0ull View Post
    I think like "Moky" if the counter is activate once - you need to change mcu - cause counter is inside of it . Maybe this solution is when you change mcu , before counter activate , you will install it and update , and go to 1.93 version and then maybe will be deactivate counter . I don't know 100% , but one mcu cost 20$ with 50 tokens or maybe already have whit 500 token and that is fine for my .
    Yes the update sounds very nice with obd improve , Ford solution but i will wait to see little bit , for now after few changes on my kess v2 work very nice .
    But i have one question - can Kess v2 clone read/write SID 803/803A and sid206 by obd or only AVDI can do it ,or other option is only BDM .
    Overshull....question..I can use my clone. With the version 1.93? Is it possible? What I have to do?
    Thanks. .
  14. #734
    Oct 2011
    Usa
    It will not be updated to 1.93, only 1.89 cars active
    about the counter, the modified version of software
    dont take care of it, so will work forever!
  15. The Following User Says Thank You to jmcartec For This Useful Post:
    euroscan1 (13th November, 2013)
  16. #735
    Jul 2013
    Alientech K-Suite Full Upgrade
    This update does not work, is a unique software
    does not enable the cars Version 1.93
    DO NOT BUY, DO NOT WORK
  17. The Following User Says Thank You to mischiatti2 For This Useful Post:
    euroscan1 (15th November, 2013)
