Page 9 of 140 FirstFirst ... 45678910111213141959109 ... LastLast
Results 121 to 135 of 2097
Thread: kess v2 clone
  1. #121
    heteromies
    Guest
  2. The Following User Says Thank You to heteromies For This Useful Post:
    mexanico1971 (8th April, 2013)
  3. #122
    hello can anybody test on trucks like daf man etc? It works witch 24Volts???
  4. #123
    Jul 2011
    Quote Originally Posted by damiantucha View Post
    http://www.digital-kaos.co.uk/forums...23#post1933023
  5. #124
    Jan 2013
    clone wont work on 24 volt systems, 12v only
  6. #125
    Jul 2011
    Quote Originally Posted by galsy View Post
    Yes, I know this, it's been said a few times that components on the PCB are under spec'd. Thanks
  7. #126
    Dec 2010
    If obd (K-line and can) are working and software is same as original tool, it should work in trucks 24v, just make an obd pinout and cut the 24v suply and use a small batery to suply the kess.
    A bit messy with wires, but shoulnt burn componets and work if software still have truck drivers
  8. #127
    Apr 2012
    Wonderland
    tested fiat iaw 4AF kline read ok
    tested EDC17CP14 VAG tricore don't work
    ProTuner since 1999
  9. The Following 6 Users Say Thank You to atomiczen For This Useful Post:
    dav29200 (20th April, 2013), mauronow (15th April, 2013), mexanico1971 (15th April, 2013), toni23 (16th April, 2013), vasco fernandes (16th April, 2013), wiski (15th April, 2013)
  10. #128
    moky's Avatar
    Behind you
    hi receive mine.software don't work Under Windows 7 64 ?
  11. #129
    Apr 2012
    Wonderland
    tested valeo johnson PSA J34P bootmode ST10Fxxx work ok
    ProTuner since 1999
  12. The Following 3 Users Say Thank You to atomiczen For This Useful Post:
    dav29200 (20th April, 2013), mauronow (16th April, 2013), wiski (16th April, 2013)
  13. #130
    moky's Avatar
    Behind you
    Test edc15P vag R/W ok
  14. The Following 2 Users Say Thank You to moky For This Useful Post:
  15. #131
    Nobody complains that not work, it?s making a large number of ECUs (didn?t see much MED17 VW with Tprot or PSA/BMW tests), so it?s quite relyable...
    The question that remains: it DOES ou DOESN?T block after 50 flashes without internet conection as the original one ?
  16. #132
    Apr 2012
    Wonderland
    Quote Originally Posted by OVERSPEED View Post
    the first issue found it's edc17 that don't work
    tested today a edc17cp14 in tricore bootmode with galletto 2 3led clone modded, kess v2 clone and kess v2 ori
    no id with the clone
    work perfect with the ori
    i don't know if internet connection is needed after 50 flash
    ProTuner since 1999
  17. The Following User Says Thank You to atomiczen For This Useful Post:
    wiski (21st April, 2013)
  18. #133
    moky's Avatar
    Behind you
    it's not a good news for tricore but we must test on others tricore ecu.I don't have ecu on hand but will test as soon as possible.
  19. #134
    moky's Avatar
    Behind you
    Plowman you said some page ago tricore mode work.Did you test ?
  20. #135
    Aug 2012
    Quote Originally Posted by moky View Post
    Of course! How else would I know if it worked?
