File is Ok, is partial read, but is 100% usable.
I send you DPF off file.
dpf is on, file is 100% original and good.
it's not full read but file is good
EDIT:
i don't see camil post, sorry
Ecu tuning, DPF, EGR and FLAP remove
test and report
WinOLS 5, FGtech, Piasini, Powergate M, Byteshooter, OptiCan Dual II, EVC BDM, VCDS, BeeProg+,Ktag, Kess V3, Autotuner, Bflash
Fileservice
no thanks no pass
since Galletto read partial file. I can write that partial fapoff file withaut Demag ecu . because i dunot have becap complet file
yes you can, bt if you want to be safe read ecu with BDM for full dump
problrm is that the connector of the BDM. from the opposite side of the lid. so I have to take plate of the cooler, which is glued rubber. I am afraid not to damage the board. So if someone is 100 percent sure that I will not damage the contents of the ecu bay writing agen with galieto 2 .
did it 5 times with FGTech2 . only last time got error about cheksum after 10 km driving, but that could see only with diagnostic.
Hi all I have same Ecu 0281 012 103 Need to check my Bdm file with another one, i am getting internal fault codes, Can someone check or giveme a file, Regards P.
code ecm 7700 ?
xc90.zip
Can you fap off in this file
