clem58 (2nd April, 2013)
Here is a sneak preview of the word done so far, please bear in mind that this is still WIP ( work in progress ) and it is far from finished, but it should give you a idea of where things are going with the project.
you can keep up with developments via the GIT here
extract the following archive and FTP the OnDemand folder toCode:https://github.com/oe-alliance/oe-alliance-plugins/tree/master/OnDemand
/usr/lib/enigma2/python/Plugins/Extensions/
then issue the following command via a telnet session.
init 4 && opkg install python-lxml python-beautifulsoup python-dnspython && init 3
This plugin will only work with the ViX image at present.
Fix for 3player ( strait off the telly ).
extract the following archive and FTP the threeplayer.py file to /usr/lib/enigma2/python/Plugins/Extensions/OnDemand/ overwriting the file already there. a reboot is required for the fix to take hold.
Some info on these plugins would be nice ?
Try it and find out !!.
if you look at the GIT i linked to you will see exactly what this plugin is about.
Small fix for 3player. 24.02.13
[OnDemand] threeplayer.py - Better Error Handling
Make better use of error handling from findPlayUrlExtract the 3player.py file from the attached archive and FTP it to /usr/lib/enigma2/python/Plugins/Extensions/OnDemand/ overwriting the file already there, a reboot is required for the fix to take hold.Code:https://github.com/oe-alliance/oe-alliance-plugins/commit/50a80b0e36c647e3373aa8b86fd084f7a6f66b00
I followed the instructions unzipped the file copied OnDemand folder to the location and logged into putty via telnet.
Logged in username as root and pasted the command and press enter.
The box froze for a while and didn't return so had to power off and reboot?
Once into plugins said some plugins were not installed have i done something wrong?
is you box an original or clone ?running what image as there maybe a standard to use.
The latest on demand file is 10/03/2013 maybe RD could post it for others.
Be aware that the standard OD player is currently not working on Blackhole 2.0.1. There are some modded files on the BH forum.
I see it should be available for download on vix image.
OE-Alliance OnDemand
Full changelog.
29.01.2013
-[OnDemand] add new plugin.
30.01.2013.
-[OnDemand] cleanup and fix imports.
-[OnDemand] stop possible BSOD.
31.01.2013
-[onDemand] Update OnDemand/src/plugin.py Varies bug fixes
-[onDemand] Update OnDemand/src/plugin.py whoops
-onDemand] Update OnDemand/src/bbciplayer.py BBC Varies bug fixes
04.02.2013
-[onDemand] A complete rewrite of the threeplayer.py plugin
-A total rewrite of the threeplayer.py file to bring it in line with the format of the other onDemand plugins. New method to parse the html using lxml so a new dependancy for this to be installed also.
-The plugin still needs work for the findPlayUrl function, this is very slow but I could not figure out a quicker way to get this to run.
-[onDemand] threeplayer.py tidyup
-Some of the code vs the Git became out of line so tidyup. Also, existing import "from . import _" caused Import Error so removed.
-[OnDemand] fix translation code. this import IS required.
-[onDemand] Fix Tabing issues
-Tidy up the code as I had lots of tabbing issues. Also, only call findPlayUrl for the Section "Straight off the Telly" as we can determine the mp4 url for the other sections by using the icon url.
-[onDemand] Add Icons
-[onDemand] Remove thumbs.db
-[onDemand] Added judge's update for plugin.py
-[onDemand] Fix threeplayer.py skipping shows
-When pulling the media data I was looking for div's that had and id = "gridshow" instead of an id containing "gridshow". This resulted in every 5th show getting dropped (Good spot Sean)
-Also, putting in some of Seans code to remove the call to BeautifulSoup in the function findPlayUrl so this should help speed up getting the stream going.
-[OnDemand] cleanup and fixed line endings (now LF (Linux) instead of CRLF (windows)).
06.02.2013
-[OnDemand] Update rteolayer to use lxml
-A good few changes to rteplayer.py
-Mainly use lxml to retrieve the feeds
-Update to categories to also show a thumbnail
-Change location for default icon if show images is false
-A small change to threeplayer.py
-Change location of the default icon if show images is false
-A general tidyup on tabs in rteplayer.py and default.py also
-[OnDemand] fix build.
07.02.2113
-[OnDemand] About Text Fix
-The format of the about text was all out of line
-[onDemand] Remove duplicate screens & code
-Moved set-up show images to main screen
-Removed duplicate about screens as it's handled in main screen
-[OnDemand] Use same screen as other ondemand players.
09.02.2013
-[OnDemand] itvplayer.py - Use TUNLR for Non-UK IP
-A quick update to check for an error returned from urllib2 when retrieving the stream url.
-If an "InvalidGeoRegion" error is thrown then launch again using the TUNLR IP.
10.02.2013
-[OnDemand] itvplayer Extra Debug Output
-When a HTTPError is thrown but it is not a Geo error need to print the output of the exception.
21.02.2013
-[onDemand] Updated with Markus's Icons
-Still needs 3player icon & large icons for default players.
22.02.2013
-[OnDemand] threeplayer.py fix Straight Stream
-The html that was being returned for the Striahgt off the Telly streams had changed so I needed to change the findPlayUrl function to retrieve the mp4 url.
-Changed it slightly also so that it should future proof it a bit if it changes again in the future.
-Also added a few MessageBox popup's to display an error if this happens in future.
23.02.2013
-[OnDemand] threeplayer.py fix crash
-Need to indent findPlayUrl to include it within the StreamThumb class
-[OnDemand] threeplayer.py Fix Crash
-When moving findPlayUrl within the StreamsThumb class I didn't include the self text when calling the function.
24.02.2013
-[OnDemand] threeplayer.py - Better Error Handling
-Make better use of error handling from findPlayUrl
03.03.2013
-[OnDemand] add common library module, recode menu to use new common code that can be shared across plugin's
-[OnDemand] add 4OD, and cleanup, and use new commons library.
-[OnDemand] OUG Fixes and Default Image
-Tidy up the data parsing for the RTL streams and also fix the navigating issues.
-Pass the defaultImg to the commonModules for each player
-[OnDemand] OUG - Thumbnail Retrievel Fix
-OUG handles humbnails slightly differently than the other plugins. Needed to make a slight adjustment in CommonModules.py when constructing the thumbnail name.
04.03.2013
-[OnDemand] Attempt GEO fix for 4OD
-It was higlighted that that the streams returned from 4Od beginning with rtmpe://ll worked and the rtmpe://ak ones didn't.
-I have added a fudge to loop for MaxTimes for Non-UK users to try and obtain an rtmpe://ll stream. If not then an error message is thrown
06.03.2013
-[OnDemand] Add Search option to rteplayer.py
-As the title says, a new menu item has been added to search for programmes on the RTE Player Website
-[OnDemand] Add Search option to threeplayer.py
-A new search menu item has been added to the 3 Player to search for programmes on tv3.ie
07.03.2013
-[OnDemand] Updates and Bug Fixes
-bbciplayer.py
- Add a new Search Menu Option
- Handle parsing Dates more efficiently
- Fix invalid link for Sports Category (Thanks Mickd)
-rteplayer.py
- Move Search menu item to top of list
-threeplayer.py
-[OnDemand] Add a Search Menu Option to fourOD.py
-A search option has now been added to the 4OD plugin. One small issue is that the search source is from channel4.com and some of the results are not available on ps3.channel4.com. I output an error message when this occurs.
-[OnDemand] Add Search menu option for itvplayer.py
-Add a search option for itvplayer.py
08.03.2013
-[OnDemand] Fix Stream Data containing &
-Update for all players to handle the & character.
-[OnDemand] Fix some data parsing Issues
-Issues with dates and also data not being a string.
09.03.2013
-[OnDemand] add option to hide from 'MainMenu, PluginBrowser & Extensions', clean up py code.
-[OnDemand] add license to plugin.
-[OnDemand] tweak main menu, also tweak the list.
-[OnDemand] tweak RTE image.
-[onDemand] fix build
-[OnDemand] fix About screen keymap.
-[OnDemand] All Players - Pass Back Duration
-Passing back duration fiels (if it exists) from each player to commonModules
-Also some code tidyup
-[OnDemand] Fix findPlayUrl stream Error
-Another good spot by mickD.
-TV3 have changed the netConnectionUrl for the Straight Off the Telly section. They are now rtmpe url's instead of rtmp url's.
10.03.2013
-[OnDemand] fix EndOfFile exit.
-[OnDemand] tweak config menu.
-[OnDemand] more cleanup and streamline code.
-[OnDemand] be less verbose.
-[OnDemand] add Title to EpisodeList screen.
-[OnDemand] add duration to screen.
-[OnDemand] fix Search.
-[OnDemand] list tweak.
-[OnDemand] New Config option for Preferred Quality
-Removed the need to select stream quality for BBC & ITV players. Instead a new config option has been added to set your preferred quality and the player will try best to match that qulaity.
-[OnDemand] Update required for plugin.py Missed adding the ConfigSelection type
-[OnDemand] Preferred Quality Changes For BBC iPlayer and ITV Player if we have already found the preferred quality setting then break and stop looking further. Faster to play the stream potentially.
-For BBC iPlayer and ITV Player if we have already found the preferred quality setting then break and stop looking further. Faster to play the stream potentially.
-[FanControl] remove unused module.
13.03.2103
-[OnDemand] fix typo's.
-[OnDemand] use 'Regular' font for Title in the embedded screen as other skins may not have 'Boldit'.
-[OnDemand] Add a HD Option for BBC iPlayer
-New config option to play the HD streams from the BBC iPlayer.
-Currently this will only work for UK users, limelight doesn't seem to send data for HD streams.
-[OnDemand] Add BBC HD Streams for Non-UK A big thanks to Rogerthis for this info!! We can now play HD streams from outside the UK also
22.0.3.2013
-[OnDemand] Add ABC iView Player
-New player for our Oz users, Currently only available to users in Oz I'm afraid.
-[OnDemand] Update Credits
-I forgot to add credits to Andy Botting for his great work on the XBMC ABC iView Add-on.
-[OnDemand] Update to ABC iView
-I left a debug piece of code for exception handling in the plugin by accident. This would have prevented any categories from returning.
OnDemand can now be added to the new 2.0.2 BH images with the following Telnet command as all dependencies are now within their feeds.
init 4 && opkg update && opkg install enigma2-plugin-extensions-ondemand && init 3
please note i'm not sure if this is the very latest version with ABC iview included as i have not tested it yet.
my rte player on ondemand doesnt play....just freezes.....i see this a LOT over and over again in the log....what does it mean ??
gst_element_query_position failed in getPlayPosition
also...to explain more...i can get the menu's and listings of the videos on rte player up fine...it is only when it tries to play them...the player is stuck on 0.00 and doesn't play anything...and pressing stop gives the vix logo spinning and it takes around 7-8 minutes to go back to the previous screen...the listing of videos on rte player.
the rest of the ondeman plugin is fine...bbc iplayer, tv3 player etc..no issues.
also other streaming plugins like icefilms have no issue
The version loaded from the feed did not have ABC iview but the download from the GIT is now compatible with BH2.0.2, so just extract the files from the archive and FTP into the appropriate folder then restart enigma.
Any news of when they will get past the Geolock for ABC?
