Page 2 of 5 FirstFirst 12345 LastLast
Results 16 to 30 of 66
  1. #16
    DK Veteran ACDC's Avatar
    Feb 2011
    Hey, thanks for the upload Mr Columbo! Could you also share the pass for the archives?
  2. #17
    Feb 2011
    Can anyone help me with the connectors on the examiner? Which one is used for diag for example, and how to connect it? I don't have a cable for it. I read there is a mpx97 adapter for diagnostics does anyone know or have a drawing of it's wiring by chance?
  3. #18
    Mar 2013
    Quote Originally Posted by columbo25 View Post
    Here is my contribute, release 5.40 the last for the old dos/Win311 Examiner !
    thank you my friend.
  4. #19
    Feb 2011
    Nobody has anything for this mpx97 cable?
  5. #20
    Sep 2010
    Quote Originally Posted by ACDC View Post
    Ok here is a bit about the cables, you have a upgraded VCI card with VCI and CAN/EOBD see picture below,
    in the pictures of the cables I have numbered the pins in accordance with how I've counted them, I've done
    it this way in an attempt to avoid confusion on which pins at each end of cable that should be connected
    together.
    VCI cable, Fiat 3 pin diagnostic connector it is also used to connect to the MPX97.
    1/K is connected to pin 4 on the 15 pin connector on the other end of the cable.
    2/GND is connected to pin 1 on the 15 pin connector on the other end of the cable.
    3/L is connected to pin 2 on the 15 pin connector on the other end of the cable.
    MPX97 is a manual switch/multiplexer with 12 positions that connects to the 16 pin OBD socket(not a real
    OBD diagnostic socket) used on Fiat/Alfa/Lansia pre CAN/EOBD, Examiner diagnostic software tells you what
    position number you should use to connect to the device you want to do diagnostic on, there are some
    electronic stuff in the MPX97 when it requires power from the 16 pin OBD socket to function properly
    but it will probably work equally well if you build a mechanical switch that connects to the correct pins.
    pin 4 connects in all positions to pin 2/GND on the VCI cable (pin 1 on the 15 pin connector that connects to the Examiner).
    pin 10 connects in all positions to pin 3/L on the VCI cable (pin 2 on the 15 pin connector that connects to the Examiner).
    position 1 on MPX97 is connecting pin 8 to 1/K on the VCI cable (pin 4 on the 15 pin connector that connects to the Examiner).
    position 2 on MPX97 is connecting pin 6 to 1/K on the VCI cable.
    position 3 on MPX97 is connecting pin 2 to 1/K on the VCI cable.
    position 4 on MPX97 is connecting pin 1 to 1/K on the VCI cable.
    position 5 on MPX97 is connecting pin 16 to 1/K on the VCI cable.
    position 6 on MPX97 is connecting pin 14 to 1/K on the VCI cable.
    position 7 on MPX97 is connecting pin 13 to 1/K on the VCI cable.
    position 8 on MPX97 is connecting pin 12 to 1/K on the VCI cable.
    position 9 on MPX97 is NC.
    position 10 on MPX97 is connecting pin 1,2,6,8,12,13,14,16 to 1/K on the VCI cable.
    position 11 on MPX97 is NC.
    position 12 on MPX97 is NC.
    CAN/EOBD :
    pin 2 on the 16 pin OBD connector connects to pin 5 on the 15 pin connector that connects to the Examiner.
    pin 4 on the 16 pin OBD connector connects to pin 8 on the 15 pin connector that connects to the Examiner.
    pin 5 on the 16 pin OBD connector connects to pin 2 and 9 on the 15 pin connector that connects to the Examiner.
    pin 9 on the 16 pin OBD connector connects to pin 1 on the 15 pin connector that connects to the Examiner.
    pin 10 on the 16 pin OBD connector connects to pin 7 on the 15 pin connector that connects to the Examiner.
    You also need a cable that connects to the battery of the car for the Examiner to function properly when doing
    diagnostic, both + and - are protected with a 15A fuse.
  6. The Following User Says Thank You to Alfa GTV For This Useful Post:
    ACDC (23rd April, 2013)
  7. #21
    Sep 2010
    some more pictures.
  8. The Following User Says Thank You to Alfa GTV For This Useful Post:
  9. #22
    Top Poster MCNexo94's Avatar
    Hello i am search CD FLASH EXAMINER v6.x or later you have ???
  10. #23
    Sep 2010
    If I remember correctly Examiner flash CD rel 5.6 is the last one, after rel 5.6 you have to use the net to get the files.
  11. #24
    i think too , after 5.60 only web
  12. #25
    The CAN interface is not OBD connector?
    Dismantled?
    Not sure your picture?
  13. #26
    Sep 2010
    Quote Originally Posted by zsoltmora View Post
    Dismantled?
    I'm not quite sure if I understand your question correctly but if are you refering to "(not a real OBD diagnostic socket)" I did not mean it physically, the OBD socket is a real one but have been differently connected inside compared with a normal OBD connector.
  14. #27
    Quote Originally Posted by Alfa GTV View Post
    Thanks Alfa GTV!!
    Thanks for the picture!
    This I would like to build electronics.
    Can you help someone?
  15. #28
    Feb 2011
    Thank you for the pictures Alfa GTV! Does anyone happen to have a wiring diagram for that eobd can connector zsoltmora posted the picture of?
    Also does anyone have the flash cd for this old examiner? I looked around for them but all the download links seem to be dead.
    Thanks in advance.
  16. #29
    Sep 2010
    Thanks in advance.
    I do not have any wiring diagram about the eobd can connector and can not exactly see what it is on the circuit board (without destroying it) because of all the glue, but it seems to be built around a Philips TJA1053 IC.
    I think that v.1.6 maybe v.2.1 is the latest version of flash CD that you can use on the old Examiner.
  17. The Following User Says Thank You to Alfa GTV For This Useful Post:
  18. #30
    Feb 2011
    Does any of you have an idea where can I get an eobd can cable? Is there a chance that it is for sale on some website somewhere?
