aveo 2010
where is the pedal position sensor
error code p0122
pedal position sensor / switch A circuit low
DIAG report by Launch
aveo 2010
error code p0122
where is accelerator pedal?
but anyway this code can mean and throttle position sensor.
check both maybe need just got clean
I can help you but only if you want me to help you
All the questions should start from what car, what year, what engine is what fuel. What are the symptoms of the problem. Only then is what you know, what fault code, live data, what you have done.
so can u tell me the location to find it
can u get pic ??
https://www.google.co.uk/search?q=ac...w=1280&bih=909
Start from throttle body check wiring - clean inside measure voltage and signals
some pdf for start and bla bla
last only pedal sensor
