Results 1 to 4 of 4
    Nov 2010
    Default help lexus gx470 keys lost
    after customer lost all keys , i used tcode pro for resetting immo in order to program new key which has 4D id 68, the key programing procedure counts forever without success, and now im*mo light is steady when i key is out , and blinks when ignition on.
    the car is lexus gx470 year 2008 USA version,
    im*mo number 89780-60331.
    hope that anyone have virgin dump for this im*mobox
    i attached im*mo data from 93LC66B
    koncimobil's Avatar
    Sep 2011
    soxxi
    post here id68 data
    Oct 2012
    jeddah
    Unplug bat(-) 5 minit then again program, first reset
    i think you need id67 for this one. immo light on means immo is in learning mode. check with a id67. another issue with id 68 is that you need 3 keys, two master and one valet to complete registration process, but once you insert the key, immo light should go off and on again when remove key, untill process is completed with all 3 keys
