Hi. I would like to know if someone could help me correct mileage to 145,250 kms from this file from a Peugeot 307 BSI version 2 -Make Valeo. The actual km is 218,373 kms. Thanks.
Hi, here it is.
regards
Here -clear history
Hi guys.
Many thanks for your dumps. I will check & see if everything's ok. Karalda- I can see from your file that from 00-5F0 everything is FF. Should I reconfigure BSI .Also upon comparing your's with pipina's I can see that the 145,250 kms is situated from lines 0670-060A but strings are not the same for the 145,250 kms. Would like to know which one to load so as not to get a non-starter vehicle. Thanks.
Hi.
Some feedback concermimg the dumps for kms 145,250. I've used both files from karalada &pipina but car does not start. Upon checking I can see that bsi is not matched to ecu. Would ike to know if it's possible to swap dumps from BSI v2 to a BSi v1.
Upload files that I put.Lock the car with the key.
Wait 2 minutes, unlocked with the key and ready
Hi Karlada.
Thks for your tips. Will try tomorrow morning. However i cannot change mileage on dash (Sagem). I have the Digimaster but it cannot read the Nec processor. Have tried powering the dash offboard for almost 1 mins but mileage stays the same.
