Page 1 of 2 12 LastLast
Results 1 to 15 of 27
Hybrid View
    Jul 2012
    Default DAEWOO LANOS Hybrid IMMO OFF????
    Hello guys
    I have one ecu from daewoo lanos Hybrid and i need clean dump without immo
    Lanos 1300cc 8V 2001-2 model
    ECU: 09388029 DLBZ No.12201599
    I can not find any program to clean this dump
    Please give me a help...
    Regards!!!
  2. The Following User Says Thank You to ChipDoctor For This Useful Post:
    seftiba (6th May, 2015)
  3. #2
    Jul 2012
    any help guys for this dump from lanos.....
    Regards!!!
    antwnhszr's Avatar
    Dec 2009
    macedonia is greek....
    put here and some element's from ecu.from car what model year?
    Mar 2010
    Cam not immo off this ecu
  6. #5
    Junior Member radeon's Avatar
    Feb 2013
    I can off immo by flash dump if type of it is HV-240, but have you any flasher for this ECU?
    By EEPROM dump I can try make virgin dump for self matching to any immo unit with at least 1 work transponder.
    Also you can match any ECU to any immo unit during key programming procedure.
  7. #6
    alclot's Avatar
    Sep 2009
    Melee Island
    Quote Originally Posted by ChipDoctor View Post
    Hello guys
    Regards!!!
    Hello gentlemen. I take your post to ask you. Is there a trick to read E2PROM with UPA? Wiring and I read, I get an error, bad Vcc 3.00V.
    Thank you in advance.
  8. The Following User Says Thank You to alclot For This Useful Post:
    honingkoning (10th February, 2017)
  9. #7
    Jul 2012
    Quote Originally Posted by alclot View Post
    Read eeprom with xprog because upa cannot
    I could not read with the upa
    Regards
  10. #8
    alclot's Avatar
    Sep 2009
    Melee Island
    Hello again. I tried to read with XPROG clone. It works but I get an error in the verification. "Verify error" When I have this error that does not read well. Is it because it is clone? Is there a trick to work ok?
    Thank you very in advance
  11. #9
    Jul 2012
    Hello my friend
    used clip pomona to read the eeprom
    and mine xprog V5.0 are Chinese not GENUINE
    Regards!!!
  12. #10
    barti122's Avatar
    Nov 2009
    Poland N
    hi try this files not tested and reply
    Sorry for my English.
    GG 5268481
    We are here to help each other unselfishly
  13. The Following 7 Users Say Thank You to barti122 For This Useful Post:
    carlab237 (21st September, 2023), eeprom241 (10th October, 2018), fronzethenight (9th October, 2019), immooff2 (19th August, 2022), min76 (26th April, 2020), Multek1 (25th March, 2021), seftiba (6th May, 2015)
  14. #11
    Jul 2012
    Quote Originally Posted by barti122 View Post
    Thanks my friend
    2-3 days i will make the test and I will Reply
    Regardss
  15. #12
    Nov 2009
    Europe
    2-3 days and nothing
  16. #13
    Jul 2012
    Quote Originally Posted by albdiag View Post
    work perfect my friend
    Regards!!!
  17. #14
    Jun 2009
    Hii,
    Můžeš ps?t,where is ee 95020?How did you load the ee?I have a similar problem with immo.Dump I can adjust and fix.
    Thank you in advance!
    Bestregards!
    no addys m8 !!!
  18. #15
    Jul 2012
    Hello Friend
    Write this dump
    Pass by PM
    DAEWOO LANOS Hybrid CLEAN SOLUTION.rar
  19. The Following 4 Users Say Thank You to ChipDoctor For This Useful Post:
    carlab237 (21st September, 2023), Multek1 (25th March, 2021), philipcoin (13th June, 2015), sico21003 (11th November, 2020)
