Hi mates,
I have hyundai sonata 2007 with ecu sim2k-140.
please i need help to get the vin number or pin code from dump (29BDD160).
Thanks in advance,
Regards.
Hi mates,
Thanks in advance,
Regards.
Wrong chip. What make is the ECU? post a photo of it.
Dear mate,
it seems that no programmer support this ecu to make key from dump,not even tango.
this ecu for sonata 2007 with automatic gearbox engine 2.4 with motorized accelerator pedal .There are 2 chips inside.(29F400 for gearbox) and (29BDD160 for engine).
The29BDD160 is the chip which contains pin code and keys.
Tango programmer supports only sim2k for manual gearbox(in these ecu there is only 1 chip"29F400" and of course it is for engine.
I have tried to search into 29BDD160 dump to find out the vin but in vain.
any one who has a similar ecu with known vin or pin code would help.
Thanks.
it is (SIM2K-140) (39100-25061)
I have never done one but ICC is saying locate and read S29CD016J. if you can then I shall be able to give you a pin code.
yes mate,This is it.it is the same chip.
Getting an error, which means that dump is no good. What did you use to read?
BDM100,anyway here is an other dump from an other ecu.Try it please.
Thanks.
did the second dump work?
Got wrong or unsupported dump file. It does not tell me what the file should be.
what option did you make on ICC?what car,model,year,ecu?
it could be a new version that it has a different code address so ICC can not recognize it.
in order to be sure,you may please try some dumps that i already downloaded from Dk.
I have a feeling that all the dumps are full flashes.
