Results 1 to 9 of 9
    May 2011
    Default VIVARO 2.5 2007 speed limit vmax
    Hi.
    I must disable speed limit in vivaro 2.5 cdti 2007.
    Where is limiter set?
    I can read it with BDM, and have opcom.
    Br.
    Netherlands
    Could be Flash or EEprom.
    Post both.
    May 2011
    Galletto or BDM?
    0281013363 edc
    Aug 2011
    Default ecu
    galleto not read this ecu,I try to read renault master with the same ecu edc16 and number
    Can be done with Clip by selecting identical model in the Renault range then using special commands.
    May 2011
    BDM is best and safe yes?
    May 2011
    Files in attachement.
    I think that speed limit is in flash becouse it was set before by obd.
    speed limit is set on 140kmh on dash so ithink 128-130 real.
    I need to disable FAP too, can You?
    Aug 2011
    Quote Originally Posted by JustMeAgain View Post
    yes but clip copy only injectors coding and configuration from that ecu !
    Senior Member Novik_UA's Avatar
    Not only injectors coding.
    With clip go to service coding
    In UCH look to LC119 - with or without speed limit
    and in motor ECU LC121 - with or without speed limit
