I have a problem with a 2007 Ford Focus 1.6tdci edc16c34.
The dpf was removed , but i have an engine malfunction error on the dashboard.When I try to read the errors i get no dtc s. It won't rev more than 3000 rpm . The owner said that someone already modified the flash for dpf off.
Can somebody have a look ? I can't find the adress to try switching off .
Op3n (27th April, 2016)
Op3n (28th April, 2016)
Luca or Mateus please upload ori for this Ford.
of course bad file made by sw can make car go into limp mode
I understood. I didn't make any modifications on this file , so the previous person did well. How can i get rid of the Engine Malfunction message on the display ?
your file with dtc on...
WinOLS (11004.rar
I tried this file and it turned out to be a problem with the glow plugs ( p0380 error ) . Changed the glow plugs and everything is ok.
Thank you very much !
Hello again ! I tried to modify by myself this dump for dpf off. EDC16C34 Ford Focus 1.6 tdci.
I want to know if it is ok to be written? It is the 3 switch method at address 1E8060 . Thank you. I don't want to choose ecusafe or volta.
Hi.
Please Help remove FAP Ford focus II 1.6 TDCI.
Hi.
Your file fap off.
Hello
I need to remove the DPF and fuel additive from a 2006 Focus bhp.
It also has the dpf pressure sensor error.
Help to be helped my friend.
Hi just a bit dofferent problem but same engine. Can someone tell me (and be able to do mod) is possible to leave filter on car and just off fuel addictive system? I know that whole tank is enough for about 100k miles so car will not surviwe anyway but just need to do MOT to pass emission. Ive tryied do with facm but it wont change flag from rmpty to full - (ivedone everything, all adaptations procedures read tousants of posts about and only one thing wich block regeneration on my car is that facm dobt see that tank is full... so car is in regen mode All the time!! Force burn, forced burn while moving nothing works until system will get signal that bloody tank is full - and it will NOT be full because level sensor probably made for NASA just lost connection and cant be fixed (damaged after fix) if system can be cheated with excact resistamce or some othe way (other than buy a new tank) will be also good.
anyone? Will pay for good solution. Got ids and kess v2
just forgot to mention car is mazda3 2008 1.6 mzrcd fap (dpf with fuel addicteve fluid- not adblue!)
... the level sensor faults come, when there are no enough additive in the additive tank (level is low). It's kinda expensive (for some people)... If you don't want to buy the additive, just buy 1-2 liters of diesel, and add diesel to additive tank, and reset the level as the diagnostic equipment asks Never had faulty level sensor
