Yoour file dpf off
Yoour file dpf off
Hi.
Please Help remove FAP Ford focus II 1.6 TDCI.
THX
Sorry dump Ford1.6 is error ford org is OK
I need FAP Off for Ford focus 1.6TDCI please
EDC16C43 1037391374
Thanks for help
DO NOT USE MPPS FOR THIS TOOL. IT KILLS CARS!
your file, password in PM
Ecu tuning, DPF, EGR and FLAP remove
PSAXSEVOLUTION (28th June, 2013)
Hi.
Please Help remove DPF Focus 1.6 2007r ECU edc16c34
0081A010:1
9643626080
MPPS
THX
Do not use mpps m8.
"IF YOU THINK PROFESSIONAL PEOPLE COST YOU A LOT, IS BECAUSE YOU DID NOT KNOW HOW MUCH WILL COST YOU AN UNQUALIFIED"
Solved. THX assitutto
assitutto (26th June, 2013)
Hello
I need Help please removing DPF OFF Focus C-MAX 1.6 2006r ECU edc16c34
guys just get off the bit of -1% to address 1e806c! dpf off
Attention is true for all software
Ok. quick question put mod file Dpf off on 2007 Focus
Edc16 etc,
when ignition on still says Engine malfunction etc, No codes on diags,
someone said need to reset ash counter,
true . False ?
will snapon clear the warning, as i say no faults in system just the warning on dash remains?
also someone said disconnect fap additive tank under rear seats ? anyone Please ??
