What response you get from tuner?
Mates can you please verify job of one chiptuning company.
Car is passat 2001, 1.9tdi avb engine 74kw.
I have attached ori and modified file.
Can some one check this job because car is driving the same....
Would like to know what you think about this.
Thanks for help..
Real engines don't need forced induction
Who needs a turbo when you have a stupidly quick naturally aspirated engine?
He will change the map again but would like to know is everything ok with this file? This map was modified properly?
Tune is almost OK, but can have a bit more power (lower/mid range).
Is your MAF 100% OK ?
I do not like anything like this one this file.
Congratulate him for using ECM
Of course it could done better, but in my life i have seen other bad horrible mods, so thin is very human and will normaly nothing damage the Engine or something like that ....
No matter what tool is used to tune, ECM, Winols, etc... Important is the man who use the tool. :-)
@cheester
you feel really no difference to original ?
not the best-but definetly not the worst ive seen.....just needs adjusting more in the right places...
MAGPRO X17--AT-200--SCANMATIC BENCH--PCMFLASH--MITSUBISHI MUT-III---OPENPORT 2 MMC FLASHER
its definately a safe tune but you should be feeling a good difference.
As Eddie says you should log your MAF on channel3 and boost on channel 11. If your not gettting minimum of 800mg/str i would get a new maf
overall is ok.. should feel more than 15-20hp maybe
Hello
The tuning is done properly. Since AVB has the small gearbox and clutch and Passat is a heavy car this is a safe tuning. Otherwise the clutch can slip.
Regards,
filecloud
its not un common for the clutches to start to go after a remap-esp on the pd.by the time people come for a remap the car/clutch has already done some miles and is worn already.
I personaly do in most cases a bit more IQ at low-mid RPM range and at the dauration maps not increase so much at the high range. but all dependent an customer & car...like filecloud say.
BR
It's good. Sure you could get more, but it's good.
Pro VAG Petrol Tuning | Pro DPF Removal | MED17 TPRot Removal
this is deference
Thanks lads for opinion. Car is driving like on ori map. No difference.
But engine working good. No smoke also. I see this first time
No difference after mod.
Maybe you are right with MAF sensor. I will check this and let you know.
