Try this dump - but im not sure the speed is only in eeprom
Now i set to 100km. if work i will set new value
Also im not sure about checksumm of file- i try in Master III EDC17C11 -there not checksumm depends in eeprom
BR
Pass in PM
BR
Pass in PM
Im here to help and to be helped
In the internal flash the speed limit 162 km / h. I installed it through the VAS5054A. Check it soon. Thanks!
What was speed lim in flash before you set to 162km/h??
speed limit was 90 km / h.
If not work only in eeprom i will remove in flash too- but first test and report please
Last Master III 2.3dci EDC17C11 i make need to disable speed from flash and eeprom too
OK, thanks. I will write a report in two weeks.
